29640 Discussions
Numerical deviations between Sandy-Bridge and Haswell
mriedman
I'm seeing slight numerical deviations between Sandy-Bridge and Haswell when I run the very same executable.
It is built with ifort17, plain Fortran, run with a single thread, not using MKL ot other external libs, linked with -static-intel, run on the same OS (RHEL7). Compile switches are quite aggressive but that does not explain (-O3 -xAVX -fp-model fast=2 -no-prec-div -no-prec_sqrt -ftz -fast-transcendentals). Sequential execution should exactly reproduce.
The usual suspect would then be uninitialized data. These are not detected by any of the known runtime checks. If they cause the deviation then I should be able to reproduce the deviation even with the same processor type. But I can't. I tried a number of different machines. v3 and v4 produce identical results on any machine.
So I can't see any further reason for such behaviour except maybe changes in the FPUs between v1 and v3. Is there any data or explanation ?
The deviations are really small however in my industry such behaviour is not easily accepted.
Steve_Lionel
No, -fp-model has no effect on the math library. What you may want is -fimf-arch-consistency
jimdempseyatthecove
At the beginning of your program add
USE, INTRINSIC :: IEEE_ARITHMETIC
TYPE(IEEE_ROUND_TYPE) ROUND
CALL IEEE_GET_ROUNDING_MODE(ROUND)   ! Stores the rounding mode
PRINT *, ROUND
Run on both CPU types to verify initialized rounding mode is the same
You may also want to call IEEE_SET_ROUNDING_MODE to your choice of modes: IEEE_DOWN, IEEE_NEAREST, IEEE_TO_ZERO, or IEEE_UP
Jim Dempsey
Steve_Lionel
The math library does CPU dispatching, which can result in small differences. See sc13.supercomputing.org/sites/default/files/WorkshopsArchive/pdfs/wp129s1.pdf for more details.
mriedman
Thanks, gentlemen,
rounding mode is always IEEE_NEAREST.
@Steve, will -fp-model precise disable this CPU dispatching ?
Michael
Steve_Lionel
mriedman
Thanks, indeed that option resolved the issue.
The price is a 10% runtime increase. Compiled code is not affected but the intrinsics are (pow, log). They roughly double their runtime.
Anyway I now have an explanation and - if somebody insists - a solution.
Steve_Lionel
As I wrote in the presentation: Accuracy, Performance, Consistency: Pick two.
