I experienced a problem when usign -O3 optimization on code with nested loops acting on allocatable arrays. The following shows a minimal example of my code:
--->main.f90
program main use norms implicit none integer :: Nx,Ny,Nz complex, ALLOCATABLE, DIMENSION(:,:,:) :: arr real, ALLOCATABLE, DIMENSION(:) :: normParts1 integer :: i,j Nx=4 Ny=4 Nz=4 ALLOCATE(arr(Nx,Ny,Nz), normParts1(Nz)) arr(1,1,1)=(1.D0,0.D0) arr(1,2,1)=(1.D0,0.D0) arr(4,4,1)=(1.D0,0.D0) write(*,*) norm(Nx,Ny,Nz,arr) CALL normParts(Nx,Ny,Nz,arr,NormParts1) write(*,*) NormParts1 end program main
--->norms.f90
module norms
implicit none
contains
function norm(Nx,Ny,Nz, arr)
implicit none
INTEGER, INTENT(IN) :: Nx,Ny,Nz
COMPLEX, INTENT(IN) :: arr(Nx,Ny,Nz)
REAL :: norm
INTEGER :: i,j, k
norm=0.D0
do i=1,Nx
do j=1,Ny
do k=1, Nz
norm=norm+abs(arr(i,j,k))**2
end do
end do
end do
end function norm
subroutine normParts(Nx, Ny, Nz, arr, normParts1)
IMPLICIT none
REAL :: normParts1(Nz)
INTEGER, INTENT(IN) :: Nx, Ny, Nz
INTEGER:: i,j,k
do k=1,Nz
normParts1(k)=0.0d0
end do
!do k=1,Nz
do i=1,Nx
do j=1,Ny
do k=1,Nz
normParts1(k)=normParts1(k)+abs(arr(i,j,k))**2
end do
end do
end do
end subroutine normParts
end module norms
when compiled with composer_xe_2013_sp1.0.080 and -03, normParts gives an incorrect result: norm=3, normParts=(2,0,0,0).
When compiled with 02, or when interchanging the loop order, such that k is the outermost loop (which would indeed be more efficient) everything works fine and norm=3, normParts=(3,0,0,0).
Is there anything dangerous in my code that may lead to behavior? Can this behavior be expected or is there something weird about this?
This appears to be a defect in the Composer XE 2013 SP1 initial release (pkg. 080) that you noted using. I don't have a specific internal tracking id that I can associate the incorrect results/behavior to but the defect appears to be fixed beginning with the Composer XE 2013 SP1 Update 2 (pkg. l_fcompxe_2013.1.2.144) release.
At your convenience, if you can upgrade to the Update 2 that should resolve the issue or you might consider upgrading to the latest Composer XE 2013 SP1 Update 3 (l_fcompxe_2013.1.3.174).
