29400 Discussions
!$OMP ATOMIC and !$OMP CRITICAL directives inside conditional statements
Ioannis_K_
As the title of my post suggests, I wanted to ask whether it is possible to combine OpenMP ATOMIC/CRITICAL directives inside an IF.... ENDIF statement.
An example code structure is provided below:
!$OMP PARALLEL DO
do i1 = 1,100000
     if(IndexV(i1).gt.0) then
          !$OMP ATOMIC
           Kff( IndexV(i1) ) = Kff( IndexV(i1) ) + 1
     endif
end do
Will the !$OMP ATOMIC directive inside the above conditional statement work?
Many thanks in advance!
Steve_Lionel
You need a !$OMP END ATOMIC, but I don't see any reason it shouldn't work.
WHARR5
!Hello Ioannis,
 !I have run your DO Loop (incorporating your IF-ENDIF structure) as a stand-alone program and it executes just fine! I have added a MAXTHREAD statement just to make sure OMP is in effect, and I have initialized your two arrays (as I am sure you have done earlier in your program). Otherwise, I executed the program in Visual Studio's !RELEASE mode, using Intel's Fortran compiler. Here is the program:
     program TestATOMIC7318
    USE OMP_LIB
     implicit none
     ! Variables
    INTEGER::MAXTHREADS
    INTEGER::i1,IndexV(100000),kff(100000)
     ! Body of TestATOMIC7318
     MAXTHREADS=OMP_GET_MAX_THREADS()
    WRITE(*,'(24X,A,I3/)')'Local Max Threads by OpenMP: ',MAXTHREADS
     IndexV=0;kff=0
    !$OMP PARALLEL DO
     do i1 = 1,100000
             !$OMP ATOMIC
         endif
     end do
     Print*,'Hello World'
       end program TestATOMIC7318
 !Regards,
!Bill
WHARR5
Hello Ioannis,
Initializing your 'IndexV' array with all 0s, as I did, prevents the program from ever entering your IF-ENDIF structure. Sorry about that. However, I have run it with initial values put into array 'IndexV' and the program continues to execute without error.
Bill
Ioannis_K_
Hello Bill,
Thank you for looking into this. I have also managed to successfully run a program with code similar to the one I originally posted. I still decided to ask in the forum, to double-check and make sure that I could use the ATOMIC directive in the specific case, as I wanted to use it for a much more complicated program of mine. I wanted to ensure that I would not spend a significant amount of time making changes which could not work!
I can verify that using the ATOMIC directive in conditional statements of my "complicated program" works fine. In fact, I see a significant enhancement in performance compared to the previous version, which was using a rather large !$OMP CRITICAL construct instead of using individual !$OMP ATOMIC directives at specific lines.
Yannis
