OMP Compiler Flag
mattsdad
With no OMP directives in the code, I get different results from load modules generated with "Process OpenMP Directives" set to "Generate Parallel Code" vs. "Disable". Why?
Because /Qopenmp implies /automatic and if you have uninitialized variables or assume SAVE semntics you'll see a difference.
