29343 Discussions
OOP fortran: can not make a subroutine execute different objects
luis_gc_rego
I need some help please.
In this code I create two objects (MM and FF) that extend an abstract
object (MF). Then I have a subroutine (execute_MM_or_FF) that is
supposed to handle both objects (MM and FF).
I tried several ways of doing it but none worked; this is an example
for which I get the error message
error #8169: The specified interface is not declared.   [OUTPUT]
What is the problem with this code? thanks
module Abstract_class_m
    implicit none
    private
    type , abstract , public :: MF
    contains
        procedure (output_info) , deferred :: output
    end type
    abstract interface
        subroutine output_info( me , iter)
            import :: MF
            class(MF) , intent(in) :: me
            Integer   , intent(in) :: iter
        end subroutine
    end interface
end module Abstract_class_m
module MM_class_m
    use Abstract_class_m
    implicit none
    private
    public :: MM
    type,extends(MF):: MM
        integer                  :: ITMAX = 200
        character (len=2)       :: driver
    contains
        procedure :: output => output_MM
    end type MM
    interface MM
        module procedure  constructor
    end interface
contains
function constructor( ) result( me )
implicit none
type(MM) :: me
me % driver = "MM"
end function constructor
subroutine output_MM( me , iter)
implicit none
class(MM)   , intent(in) :: me
integer     , intent(in) :: iter
print*, me%driver , iter
end subroutine output_MM
end module MM_class_m
module FF_class_m
    implicit none
    private
    public :: FF
    type,extends(MF):: FF
    contains
        procedure :: output => output_FF
    end type FF
    interface FF
    end interface
contains
implicit none
type(FF) :: me
me % driver = "FF"
subroutine output_FF( me , iter)
implicit none
class(FF)   , intent(in) :: me
end subroutine output_FF
end module FF_class_m
module execute_MM_or_FF
        use MM_class_m          , only: MM
        use FF_class_m          , only: FF
        use Abstract_class_m    , only: MF
        implicit none
        public :: execute
        private
        type, extends(MF) :: OBJ
            integer          :: ITMAX
            character(len=2) :: driver
        contains
            procedure :: output
        end type
contains
subroutine execute( me , n )
class(OBJ) , intent(inout) :: me
integer    , intent(in)    :: n
    print*, me%itmax
    call me%output(n)
end subroutine execute
end module execute_MM_or_FF
program test
use execute_MM_or_FF   , only: execute
implicit none
character(2) :: driver = "MM"
integer      :: iter = 3
type(MM) :: a
type(FF) :: b
if(driver == "MM") then
    a = MM()
    call execute(a,iter)
else
    b = FF()
    call execute(b,iter)
end if
end program test
IanH
The error arises because the `OBJ` type in the `execute_MM_or_FF module` declares a binding called `output`.  There is no procedure named `output` in that module to implement that binding.  I'm not sure what your intent was here - if you wanted to override that binding in the OBJ type then you need to provide the procedure, if you just wanted the binding to continue to refer to the procedure that the binding references in the parent type, then you do not redeclare it in the extension.
I note that in your main program you are using a CALL statement to invoke `execute_MM_or_FF` - that is - you are trying to call a module.  You cannot do that.  The thing being invoked by a CALL statement needs to be a subroutine.
luis_gc_rego
My apologies, the  CALL statement to invoke `execute_MM_or_FF´ was a mistake. It has been corrected in the example program.
Anyway, my intention is to call ´execute´ having either ´a´ or ´b´ as an argument, whereas the subroutine ´execute´ in module ´execute_MM_or_FF´ handles either objects through the class OBJ that has the same parent as MM and MF
I have tried to implement this code through various different constructions. I also understand that the procedure ´output´ of OBJ should be implemented, but I actually want to inherit ouput from either MM or FF depending on the type of argument ´me´ that is passed to ´execute´.
IanH
Fortran does not support multiple inheritance, if that is what you are trying to do.
`execute` currently takes an object of type OBJ.  It can't take an object of declared type MM or FF, they are not extensions of OBJ.
Your MM, FF and OBJ types all have the same components.  Is it really necessary that they be separate types?  Could you have another type, that was an extension of MF and that acted as the parent of the other types, that had those common components?  If so, execute just takes an object of that type, and then just calls the output binding.
If not - you need to explain what you are trying to achieve.
  implicit none
  private
  contains
  end type
  abstract interface
      import :: MF
      implicit none
    end subroutine
  end interface
  type, extends(MF), abstract, public :: MF_intermediate
    integer                  :: ITMAX
  end type MF_intermediate
module MM_class_m
  implicit none
  private
  public :: MM
  type, extends(MF_intermediate) :: MM
  contains
  end type MM
  interface MM
  end interface
contains
    type(MM) :: me
    me % ITMAX = 200
    me % driver = "MM"
  subroutine output_MM(me , iter)
module FF_class_m
  implicit none
  private
  public :: FF
  type,extends(MF_intermediate):: FF
  contains
  end type FF
  interface FF
  end interface
contains
    type(FF) :: me
    me % driver = "FF"
    me % ITMAX = 20
  subroutine output_FF(me , iter)
  use Abstract_class_m    , only: MF_intermediate
  implicit none
  public :: execute
  private
contains
  subroutine execute(me , n)
    class(MF_intermediate) , intent(inout) :: me
    print*, me%itmax
    call me%output(n)
program test
  integer      :: iter = 3
  type(MM) :: a
  type(FF) :: b
    a = MM()
  else
    b = FF()
  end if
end program test
luis_gc_rego
Perhaps this is not multiple inheritance, but I finally managed a way to do what I want in the code below.
module Parent_class_m
    implicit none
    private
    type , public :: MF
        integer                 :: ITMAX = 100
        character (len=2)       :: driver_abs
    contains
        procedure :: output
    end type
    contains
    subroutine output( me , iter)
    end subroutine
end module Parent_class_m
module MM_class_m
    use Parent_class_m
    implicit none
    private
    public :: MM
        integer                 :: ITMAX_MM = 200
    contains
    end type MM
    interface MM
    end interface
contains
implicit none
type(MM) :: me
me % itmax  = me % itmax_MM
me % driver = "MM"
implicit none
module FF_class_m
    use Parent_class_m
    implicit none
    private
    public :: FF
        integer                 :: ITMAX_FF = 20
    contains
    end type FF
    interface FF
    end interface
contains
implicit none
type(FF) :: me
me % itmax  = me%itmax_FF
me % driver = "FF"
implicit none
print*, me%driver , iter+100
        use Parent_class_m    , only: MF
        implicit none
        public :: execute
        private
contains
class(MF) , intent(inout) :: me
    print*, me%itmax
    call me%output(n)
program test
implicit none
integer      :: iter = 3
type(MM) :: a
type(FF) :: b
if(driver == "FF") then
    a = MM()
else
    b = FF()
end if
end program test
