Title says it all. I just got the icc and ifort compilers installed, following a NIGHTMARE getting Xcode on, and a problem I've never seen before crops up: FIFTEEN error messages, all similar to
2011-08-10 08:47:11.591 icc[4048:60b] This process is attempting to exclude an item from Time Machine by path without administrator privileges. This is not supported.
just from a bare invocation "icc" (no files!).
I found a discussion among Chromium developers: apparently this is not new with Lion, but also appeared in Snow Leopard. SHOULD icc have root access? I shiver at the thought of a compiler gone wild, with root priviliges.
Apple's reply in the Chromium thread was unyielding: it's documented, change your ways. Can Intel fix this, or provide a patch? I've not seen this behavior before, but I'm pretty sure I was using 11.1 before upgrading. I can send the warning messages to /dev/null, but I might miss some wheat with the chaff.
System: Apple Mac Pro 1.1, Lion freshly installed, Xcode 4.1.1, although I'm only using the command-line.
Fortran XEComposer and C XEComposer (or whatever they're called) for Mac OS X, version 12.0 of the compilers.
--Ron Bruck
--Ron Bruck
--Ron Bruck
--Ron Bruck
I am thinking that the name 'icc' is clashing with some other program or application on your system. That error message is NOT an Intel compiler message.
do this:
which icc
or
icc -V
and did you:
source /opt/intel/bin/compilervars.sh intel64
And your compiler had better be 12.0 Update 5. We still do not officially support Lion until Update 6 in mid-september. However, I have 12.0 U5 working on my Lion testbed, so I'm not sure what it is you are seeing.
ron
do this:
which icc
or
icc -V
and did you:
ron
Actually, we do claim support for Lion in Update 5. I see the same behavior with Fortran on my Macbook, it's not a name conflict. Doesn't stop the compiler from working, though. Very odd. I am not a Mac expert.
Our developers are looking into this now - the issue ID is DPD200171430. It appears to be coming from the license management code.
One of our developers found that he could make the problem go away by invoking the compiler once with "sudo". Does that work for you?
the sudo trick does not work for me, nor running ifort as root.
ron
ron
The fix for this problem should be available in the next update to the 12.1 compilers which is currently scheduled for February 2012.
Confirming: Fixed in 12.1.4 20120423 (Update 10).
Whew. Finally I can actually look at compile output and see interesting stuff without having to filter out those irritating warnings.
