29280 Discussions
Odd compiler error after switching project to IFX from IFORT
Mark_Lewy
Valued Contributor I
I have an existing VS2019 solution that uses ifort 2021.5 (and earlier) to build its Fortran projects with no issues.  If I switch the Intel Compiler to IFX, I get this output (for a single file):
------ Build started: Project: simlib, Configuration: Debug|x64 ------
Compiling with Intel® Fortran Compiler 2022.0.0 [Intel(R) 64]...
mme_messages_mod.f90
mme_messages_mod.f90: fatal: can't fopen file: C:/Users/mark.i90
simlib : error PRJ0019: A tool returned an error code
Build log written to "file://C:\Source\repos\engine_bluezone\cs\simlib\Debug.x64\BuildLog.htm"
simlib - 1 error(s), 0 warning(s)
---------------------- Done ----------------------
This seems to be associated with the use of the Fortran preprocessor option (/fpp).  If I remove this option then the file compiles.  Does anyone have a workaround for this (we have some conditionally compiled code for Linux/Windows and GNU/Intel Fortran)?
I can try to create a small reproducer and upload it to Intel Support if required.
Mark_Lewy
I think I have a workaround for this now.  If I set %tmp% to c:\tmp then the output from fpp is c:\tmp\<number>.i90.  It appears that the ifx driver is confused by values of %tmp% that contain periods.
Steve_Lionel
What does the build log say? That's the more important bit.
Mark_Lewy
Good point Steve:
ifx /nologo /debug:full /Od /fpp /Qopenmp /standard-semantics /stand:f18 /Qdiag-disable:7025,7762 /warn:declarations /Qauto /module:"Debug.x64\\" /object:"Debug.x64\\" /Fd"Debug.x64\simlib.pdb" /check:bounds /check:format /check:output_conversion /libs:dll /threads /dbglibs /c /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\VC\Tools\MSVC\14.27.29110\bin\HostX64\x64" /Qm64 "C:\Source\repos\engine_bluezone\cs\simlib\mme_messages_mod.f90"
jimdempseyatthecove
On Windows, C:/Users is the folder where the user directories are stored. This is not the place where user files should be stored.
I suspect a current directory issue.
Try this:
1) Launch a oneAPI x64 build CMD window
2) CD to your work/solution folder ?? C:\Source\repos\engine_bluezone\cs\simlib ?? (wherever the xxx.sln file is located)
3)  Enter: devenv YourSolutionHere.sln
4) Then rebuild
Jim Dempsey
Mark_Lewy
Ifort build of same file for comparison:
Compiling with Intel® Fortran Compiler Classic 2021.5.0 [Intel(R) 64]...
ifort /nologo /debug:full /Od /Qparallel /fpp /Qopenmp /standard-semantics /stand:f18 /Qdiag-disable:7025,7762 /warn:declarations /Qauto /module:"Debug.x64\\" /object:"Debug.x64\\" /Fd"Debug.x64\simlib.pdb" /check:bounds /check:format /check:output_conversion /libs:dll /threads /dbglibs /c /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\VC\Tools\MSVC\14.27.29110\bin\HostX64\x64" /Qm64 "C:\Source\repos\engine_bluezone\cs\simlib\mme_messages_mod.f90"
simlib - 0 error(s), 0 warning(s)
Mark_Lewy
If you want a small reproducer for this:
1) In VS2019, create a new "Main Program Code" project.
2) Set platform to x64.
3) In the project properties, set Preprocessor->Preprocess Source File to Yes (/fpp).
4) Change Intel compiler to IFX (from right click on project).
5) Build:
ifx /nologo /debug:full /Od /fpp /warn:interfaces /module:"x64\Debug\\" /object:"x64\Debug\\" /Fd"x64\Debug\vc160.pdb" /traceback /check:bounds /libs:dll /threads /dbglibs /c /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\VC\Tools\MSVC\14.27.29110\bin\HostX64\x64" /Qm64 "C:\Source\repos\oneAPI_2022_1_1\oneAPI_2022_1_1.f90"
oneAPI_2022_1_1.f90: fatal: can't fopen file: C:/Users/mark.i90
oneAPI_2022_1_1 : error PRJ0019: A tool returned an error code
oneAPI_2022_1_1 - 1 error(s), 0 warning(s)
Steve_Lionel
I asked for the build log, not the contents of the output window:
"Build log written to "file://C:\Source\repos\engine_bluezone\cs\simlib\Debug.x64\BuildLog.htm""
You'd have to ZIP it and attach the zip.
Mark_Lewy
  1. @Steve_Lionel A build log is in my post of 01-06-2022 07:33 AM, which was built from my original project, the later post is for the hello world project and just contains the output window contents, as you said.  I'll attach a zip file containing the solution folder to this post.
  2. Opening a oneAPI command prompt and running devenv for the solution as @jimdempseyatthecove  suggested makes no difference; it still fails to build when /fpp is selected.
jimdempseyatthecove
BuildLog.htm>>oneAPI_2022_1_1.f90: fatal: can't fopen file: C:/Users/mark.i90
The hello test does not have an INCLUDE/#include for mark.i90, which is strange. The filename must be coming from somewhere.
Please check for, and contents of, ifort.cfg to see if there is anything funny with "mark" or "mark.i90".
Does mark.i90 sound familliar?
 In a pinch, you can copy fpp.exe from an earlier version of Intel Fortran into your solution folder (or is it project folder) whatever is current directory during build.
Jim Dempsey
Mark_Lewy
The only thing I can think of is that ifx is confused by my user name (mark.lewy), which contains a period.  There's not a lot I can do about that, as I am on a corporate domain.  I think it is meant to create the preprocessed source in C:\Users\mark.lewy\AppData\Local\Temp, as I have seen .i90 files left there after (presumably) VS crashes.
I assume ifx and ifort use the same fpp.exe, so copying an earlier version wouldn't help.  Remember ifort 2021.5 compiles this fine with /fpp.
Mark_Lewy
Also fails from the command line:
C:\Source\repos\oneAPI_2022_1_1>ifx /watch /fpp oneAPI_2022_1_1.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2022.0.0 Build 20211123
Copyright (C) 1985-2021 Intel Corporation. All rights reserved.
oneAPI_2022_1_1.f90
echo oneAPI_2022_1_1.f90
C:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\bin\fpp \
-D__INTEL_LLVM_COMPILER=20220000 \
-D__INTEL_LLVM_COMPILER_UPDATE=0 \
-D__INTEL_COMPILER=20220000 \
-D__INTEL_COMPILER_UPDATE=0 \
-D_WIN32 \
-D_M_AMD64=100 \
-D_M_X64=100 \
-D_WIN64=1 \
-D_MSC_VER=1927 \
-D_MSC_FULL_VER=192729112 \
-D_MSC_EXTENSIONS \
"-D__MS_VC_INSTALL_PATH=C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\VC\Tools\MSVC\14.27.29110\" \
-D_MT \
-D__INTEL_COMPILER_BUILD_DATE=20211123 \
-I. \
"-IC:\Program Files (x86)\Intel\oneAPI\vpl\latest\include" \
"-IC:\Program Files (x86)\Intel\oneAPI\tbb\latest\env\..\include" \
"-IC:\Program Files (x86)\Intel\oneAPI\mpi\latest\env\..\include" \
"-IC:\Program Files (x86)\Intel\oneAPI\mkl\latest\include" \
"-IC:\Program Files (x86)\Intel\oneAPI\itac\latest\include" \
"-IC:\Program Files (x86)\Intel\oneAPI\ippcp\latest\include" \
"-IC:\Program Files (x86)\Intel\oneAPI\ipp\latest\include" \
"-IC:\Program Files (x86)\Intel\oneAPI\dpcpp-ct\latest\env\..\include" \
"-IC:\Program Files (x86)\Intel\oneAPI\dnnl\latest\env\..\cpu_dpcpp_gpu_dpcpp\include" \
"-IC:\Program Files (x86)\Intel\oneAPI\dev-utilities\latest\include" \
"-IC:\Program Files (x86)\Intel\oneAPI\dal\latest\include" \
"-IC:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\include" \
"-IC:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\include" \
"-IC:\Program Files (x86)\Intel\oneAPI\compiler\latest\windows\compiler\include\intel64" \
"-IC:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\VC\Tools\MSVC\14.27.29110\ATLMFC\include" \
-IC:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\compiler\include\intel64 \
-IC:\PROGRA~2\Intel\oneAPI\compiler\latest\windows\compiler\include \
"-IC:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\VC\Tools\MSVC\14.27.29110\include" \
"-IC:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\include\um" \
"-IC:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\ucrt" \
"-IC:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\shared" \
"-IC:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\um" \
"-IC:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\winrt" \
"-IC:\Program Files (x86)\Windows Kits\10\include\10.0.18362.0\cppwinrt" \
-free \
-4Ycpp \
-4Ncvf \
-f_com=yes \
-MX \
oneAPI_2022_1_1.f90 \
C:\Users\mark.i90
del C:\Users\mark.i90
del C:\Users\mark.lewy\AppData\Local\Temp\22762arg2
Mark_Lewy
I've created Intel Support case 05334696 for this problem.
jimdempseyatthecove
 Try:
ifx /watch /fpp /Fi.\ oneAPI_2022_1_1.f90
IOW explicitly state ".\" (current directory) is the directory for fpp preprocessed output.
Jim Dempsey
Mark_Lewy
@Steve_Lionel @jimdempseyatthecove Adding /Fi.\ doesn't help:
C:\Source\repos\oneAPI_2022_1_1>ifx /watch /fpp /Fi.\ oneAPI_2022_1_1.f90
oneAPI_2022_1_1.f90
-D_WIN32 \
-D_M_AMD64=100 \
-D_M_X64=100 \
-D_WIN64=1 \
-D_MSC_VER=1927 \
-D_MSC_EXTENSIONS \
-D_MT \
-I. \
-free \
-4Ycpp \
-4Ncvf \
-f_com=yes \
-MX \
C:\Users\mark.i90
del C:\Users\mark.lewy\AppData\Local\Temp\226122arg2
Apparently, Intel Support cannot reproduce this.  I have a lot of other Intel Fortran compilers versions installed as well as oneAPI 2022, so I wonder whether that's the issue: XE2018U3, XE2019U5, XE2020U[124], oneAPI 2021.[1234].  I think I can get rid of most of these, except oneAPI 2021.3, which we are using as our production compiler.
Mark_Lewy
Steve_Lionel
@Mark_Lewy  you didn't include the build log, you posted the contents of the build output window, which is not the same. Jim Dempsey extracted the build log from your zip and told us what the actual error was.
Frank_R_1
ifx from 2022.1 has the same problem when TMP points to path with periods e.g  C:\a.b\tmp
ifx -c -fpp on an arbitrary file fails.
Best regards
Frank
Barbara_P_Intel
This issue with ifx is fixed in the next release. Another developer reported it a while back on Linux. I assume it's fixed on Windows, too.
