29653 Discussions
Old and Unsupported Windows SAMPLES from Intel(R) Parallel Studio XE
Ron_Green
Intel(R) Parallel Studio XE (deprecated), Intel used to provide a ZIP file with samples.  These are no longer supported.  Some may work, some may not.  As an example, the .bat files will all reference IFORT which obviously will not work. In addition, there may be older 32bit assumptions.
Attached is a zip file with just the compiler_f samples, none of the C/C++, Vtune, MKL, etc samples.  By clicking the following you acknowledge and understand that these samples are old, untested with current tools, and may or may not work, and you understand that THESE SAMPLES ARE NOT SUPPORTED
A link to the entire zipfile and again you acknowledge that these samples are not supported:
  • Samples (Intel® Parallel Studio XE for Windows Samples Bundle)
