Why does GetDC fail?
brianreinhold
I have this simple routine to draw a solid color box in the client area of a window:
MODULE PboxModule
    CONTAINS
        !> This subroutine draws a solid color box in a window.
        !> It uses the Win32 API to create a filled rectangle
        !> based on the provided coordinates and RGB color.
        !! @param IX1 Upper-left X-coordinate in window
        !! @param IY1 Upper-left Y-coordinate in window
        !! @param IX2 Lower-right X-coordinate in window
        !! @param IY2 Lower-right Y-coordinate in window
        !! @param color Packed RGB color value
        !! @param hWnd Window handle
        SUBROUTINE PBOX(IX1, IY1, IX2, IY2, color, hWnd)
            USE IFWIN
            use user32
            use win32Interfaces
            IMPLICIT NONE
            ! Declare variables
            INTEGER, INTENT(IN) :: IX1, IY1, IX2, IY2
            INTEGER*4 :: color  ! RGB color value. Must be 32-bit
            INTEGER(HANDLE), INTENT(IN) :: hWnd
            INTEGER(HANDLE) :: hDC, hBrush
            INTEGER(BOOL) :: bret
            integer :: iret, err
            ! Get the device context for the window
            hDC = GetDC(hWnd)
            err = GetLastError()
            IF (hDC /= 0) THEN
                ! IC already represents an RGB color
                hBrush = CreateSolidBrush(color)
                ! Select the brush into the DC
                bret = SelectObject(hDC, hBrush)
                ! Draw the filled rectangle
                bret = Rectangle(hDC, IX1, IY1, IX2, IY2)
                ! Cleanup: release device context and delete brush
                iret = ReleaseDC(hWnd, hDC)
                iret = DeleteObject(hBrush)
            END IF
        END SUBROUTINE PBOX
end module PboxModule
However, using the debugger I see the hDC = GetDC(hwnd) returns an absurd value, sometimes positive and sometime negative but in all cases very large. GetLastError() returns 0, but I don't know if that helps for these methods. The handle is valid.
Any ideas what might be wrong?
andrew_4619
Fortran does not have unsigned integer type so when the high bit is set is show as a negative. The hDC is a memory address and will usually be a large number. Why do you think it is wrong? The info you have posted suggests all is good.
brianreinhold
Because the box does not get drawn in the window. I pass in ix1, iy1 = 10, 10 and ix2, iy2 = 1000, 500 and RGB color red (255). Stepping through the debugger I see that the window handle is valid. I figured SOMETHING must be wrong because the window client area remains untouched after the call to Rectangle. I admit, looking at the responses it suggests that everything succeeded but I see nothing on the screen. Did I forget something stupid?
Intel advertises that it has win32 fortran examples
  • Sample SDI and MDI Fortran Windows Samples in the WIN32 folder, such as Generic, Platform, or Angle.
But I cannot find them anywhere. Would you know where they are?
andrew_4619
The old samples are well hidden and hard to find, I just happened to do that a few weeks back.....
https://community.intel.com/t5/Intel-Fortran-Compiler/Intel-Fortran-Compiler-Information-and-Frequently-Asked/m-p/1329533#M158339
On that page go to the Product Information  sections and there is a sample link that download a zip file.
andrew_4619
What are the returns of CreateSolidBrush,  SelectObject and Rectangle? Does the window get a WM_PAINT in the message loop?
GVautier
New Contributor III
Hi
If this function is not called inside a WM_PAINT message I think you need at least a call to updatewindow to force a WM_PAINT to be sent, eventually preceded by a call to invalidaterect if necessary.
brianreinhold
@andrew_4619  @GVautier  Thanks you guys for helping out. I would have never found those samples. In any case, I have extended my application to error check everything, get the hDC, and get window from hDC. I have added a PEN (and since removed). In all cases everything works EXCEPT rectangle. It always fails with error 6. My updated code (just tons of error checks that print results to a list box in the main dialog) is posted below. However, what might be conflicting is what 'Rectangle' is declared as in the intel library.
The only thing I found is
    INTERFACE
    	FUNCTION RECTANGLE(CONTROL,X1,Y1,X2,Y2)
    !DEC$ ATTRIBUTES DEFAULT :: RECTANGLE
    	  INTEGER*2 RECTANGLE
    !DEC$ ATTRIBUTES DECORATE,C,ALIAS:"_rectangle" ::  RECTANGLE
    	  INTEGER*2 CONTROL,X1,Y1,X2,Y2
    	END FUNCTION
    END INTERFACE
    INTERFACE
    	FUNCTION RECTANGLE_W(CONTROL,WX1,WY1,WX2,WY2)
    !DEC$ ATTRIBUTES DEFAULT :: RECTANGLE_W
    	  INTEGER*2 RECTANGLE_W,CONTROL
    !DEC$ ATTRIBUTES DECORATE,C,ALIAS:"_rectangle_w" ::  RECTANGLE_W
    	  DOUBLE PRECISION WX1,WY1,WX2,WY2
    	END FUNCTION
    END INTERFACE
    INTERFACE
in the file ifqwin.f90. It does NOT seem to be the same as the Rectangle win32 API used in C/C++.
Here is my updated code (unchanged except for error checks)
        SUBROUTINE PBOX(IX1, IY1, IX2, IY2, color, hWnd, hLog)
            USE IFWIN
            use user32
            use gdi32
            use win32Interfaces
            IMPLICIT NONE
            ! Declare variables
            INTEGER*4, intent(in) :: color  ! RGB color value. Must be 32-bit
            INTEGER(HANDLE), INTENT(IN) :: hWnd, hLog
            INTEGER(HANDLE) :: hDC, hBrush, hWndCheck
            integer :: iret
            character(len=512) :: message
            type(T_LOGBRUSH) :: logBrush
            hDC = GetDC(hWnd)
            hWndCheck = WindowFromDC(hDC)
            if (hWndCheck == 0) THEN
                bret = SendMessage(hLog, LB_ADDSTRING, 0, LOC(TRIM("Obtained hDC is invalid:"C)))
                RETURN
            END IF
            IF (hDC /= 0) THEN
                write(message, '(A, I0)') 'hDC Value: ', hDC
                bret = SendMessage(hLog, LB_ADDSTRING, 0, LOC(TRIM(message)))
                ! color already represents an RGB color
                !hBrush = GetStockObject(BLACK_BRUSH)
                if (hBrush == 0) THEN
                    bret = SendMessage(hLog, LB_ADDSTRING, 0, LOC(TRIM("Error Creating hBrush:"C)))
                ELSE
                    message = repeat('', len(message))
                    write(message, '(A, I0)') 'hBrush value: ', hBrush
                    bret = SendMessage(hLog, LB_ADDSTRING, 0, LOC(TRIM(message)// CHAR(0)))
                END IF
                if (bret == 0) THEN
                    bret = SendMessage(hLog, LB_ADDSTRING, 0, LOC(TRIM("Error Selecting hBrush:"C)))
                END IF
                iret = GetObject(hBrush, sizeof(logBrush), LOC(logBrush))
                if (iret == 0) THEN
                    bret = SendMessage(hLog, LB_ADDSTRING, 0, LOC(TRIM("Error getting object from hBrush:"C)))
                    RETURN
                END IF
                write(message, '(A, I0, A, I0)') 'Drawing rectangle at: ', IX1, ', ', IY1
                if (bret == 0) THEN
                    iret = GetLastError()
                    write(message, '(A, I0)') 'Drawing rectangle failed with error: ', iret
                END IF
            else
                bret = SendMessage(hLog, LB_ADDSTRING, 0, LOC(TRIM("Error getting device context:"C)))
            END IF
        END SUBROUTINE PBOX
Running it shows that everything works EXCEPT for Rectangle. Window handles are valid (test window is WS_OVERLAPPEDWINDOW), the hDC and hBrush are valid.  The error message '6' invalid handle may be very misleading if Rectangle is calling the interface specified above.
By the way, why don't I get an email notification when someone responds here? I have checked that option but it does not happen.
brianreinhold
I found the answer and I do not like it at all. First, I found the actual intel reference to the function in gdi32.f90:
    FUNCTION MSFWIN$Rectangle( &
            arg1, &
            arg2, &
            arg3, &
            arg4, &
            arg5)
    use ifwinty
      integer(BOOL) :: MSFWIN$Rectangle ! BOOL
        !DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'Rectangle' :: MSFWIN$Rectangle
      integer(HANDLE) arg1 ! HDC arg1
      integer(SINT) arg2 ! int arg2
      integer(SINT) arg3 ! int arg3
      integer(SINT) arg4 ! int arg4
      integer(SINT) arg5 ! int arg5
     END FUNCTION
    END INTERFACE
But I could NOT use
Rectangle(hDC, ix1, iy1, ix2, iy2).
I had to use
MSFWIN$Rectangle(hDC, ix1, iy1, ix2, iy2).
Then it worked. I have absolutely NO idea why I could not use the alias (and so far the alias has worked fine everywhere else)
andrew_4619
I think you have most of the answer I read your earlier post and was about to give you what you have found. In the history Intel supported migration from Microsoft Fortran which ceased in the early 90s, the Microsoft product has a load of graphics routines which later conflicted with the names of windows sdk routines. There is/was am IFWIN module that aliases the names. BTW IFWIN includes GDI32 and USER32 you shout not need to USE those directly
andrew_4619
IFQWIN has a "rectangle"
   INTERFACE
    	  INTEGER*2 RECTANGLE
    	END FUNCTION
    END INTERFACE
GVautier
New Contributor III
andrew_4619
https://learn.microsoft.com/en-us/windows/win32/api/wingdi/nf-wingdi-rectangle
BOOL Rectangle(
  [in] HDC hdc,
  [in] int left,
  [in] int top,
  [in] int right,
  [in] int bottom
That is the SDK version which is what  you wanted, you would need to add your own interface. Noting the "int" is a 4 byte integer. the interface below is 32 and 64 bit and would work with ifort/ifx/gfortran
interface ! Recatangle
    function Rectangle( hdc, left, top,right, bottom) BIND(C,NAME="Rectangle")
        import
        integer(BOOL) :: Rectangle ! BOOL
        !DIR$ ATTRIBUTES STDCALL :: Rectangle
        !GCC$ ATTRIBUTES STDCALL :: Rectangle
        integer(HANDLE), value ::  hdc ! HDC arg1
        integer(SINT), value ::left, top,right, bottom
    end function
end interface
brianreinhold
In the end I am just going with the prefixed version of the method. As it turns out I need to use the prefixed version of many methods in gdi32. As long as I know and have it written in the code comments.
andrew_4619
If you are doing that I personally would make a wapper functions e.g. my_rectangle that calls the msfwin and make a module with them all in. That way if you change compiler you only have that module to fix.
