29632 Discussions
OneAPI MKL static link fails using ifort
Multipath
We are having problems using the FORTRAN compiler to perform a static link of MKL. Here is what works and fails:
WORKS:
1. Using ld to create a shared object version of our library and including:
/Intel/Linux/oneapi/mkl/2022.0.2/lib/intel64/libmkl_intel_lp64.a
/Intel/Linux/oneapi/mkl/2022.0.2/lib/intel64/libmkl_sequential.a
/Intel/Linux/oneapi/mkl/2022.0.2/lib/intel64/libmkl_core.a
2. Using ifort to create a program and including the
-qmkl=sequential
flag.
However this ignores the specified .a versions and uses the .so versions.
FAILS:
Using ifort to create a program and using the recommendations of the Link Line Advisor
-Wl,--start-group
-Wl,--end-group
This produces pages of errors of the form:
/Intel/Linux/oneapi/compiler/2022.0.2/linux/bin/intel64/ifort ld: fmslib.a(rsdaf.o): in function `rsdaf_.h': rsdaf.f:(.text+0x21c7): undefined reference to `dscal_' ld: rsdaf.f:(.text+0x2282): undefined reference to `daxpy_' ld: fmslib.a(rsdaf.o): in function `rsdaf_.A':
rsdaf.f:(.text+0x5ea8): undefined reference to `dscal_'
ld: rsdaf.f:(.text+0x5f5f): undefined reference to `daxpy_' ld: fmslib.a(rndaf.o): in function `rndaf_.h':
rndaf.f:(.text+0x2249): undefined reference to `dscal_' ld: rndaf.f:(.text+0x2304): undefined reference to `daxpy_'
ld: fmslib.a(rndaf.o): in function `rndaf_.A':
rndaf.f:(.text+0x602d): undefined reference to `dscal_'
ld: rndaf.f:(.text+0x60e4): undefined reference to `daxpy_' ld: fmslib.a(chdaf.o): in function `chdaf_.h': chdaf.f:(.text+0x21e8): undefined reference to `dscal_' ld: chdaf.f:(.text+0x22fc): undefined reference to `daxpy_'
ld: fmslib.a(chdaf.o): in function `chdaf_.A':
chdaf.f:(.text+0x5c81): undefined reference to `dscal_'
ld: chdaf.f:(.text+0x5d93): undefined reference to `daxpy_'
Any suggestions?
Thanks, Ron
JNichols
Try the MKL forum.  There are experts there.
Multipath
What is the link for posting to the MJKOL forum?
Thanks, Ro n
Multipath
Sorry for the typo -
It should read what is the link for posting to the MKL forum?
mecej4
You may have built fmslib.a from objects produced by using a Fortran compiler different from Intel Fortran, as the trailing underscores in the missing externals indicate.
Multipath
Everything was built with the following FORTRAN and C compilers
/Intel/Linux/oneapi/compiler/2022.0.2/linux/bin/intel64/icc
Ron
JNichols
Ron:
The expert has found you, good hunting.
mecej4
Please show more details regarding the command line used for linking. In particular, show the order in which your library name and the MKL library names were specified in the linking command. If you used a makefile, please show the relevant portions of the makefile.
Multipath
The application MatrixWarrior is written in a combination of FORTRAN and C.
Intel compilers are used.
It depends on the Nvidia CUDA software and Intel's MKL.
The MKL library reference is repeated.
Here is the command line:
ifort -auto -threads -reentrancy threaded -fpic -ftz -nofor-main -ldl -o MatrixWarrior_dbg MatrixWarrior.o mw.a fmsnoshr.a fmslib.a fmsint.a fmslib.a fmsint.a yesgpu.a fmslib.a fmsint.a fmslib.a fmsint.a yesgpu.a -Wl,--start-group /Nvidia/Linux/cuda-11.4/lib64/libculibos.a /Nvidia/Linux/cuda-11.4/lib64/libcublas_static.a /Nvidia/Linux/cuda-11.4/lib64/libcublasLt_static.a /Nvidia/Linux/cuda-11.4/lib64/libculibos.a /Nvidia/Linux/cuda-11.4/lib64/libcudart_static.a -lrt -Wl,--end-group /Intel/Linux/oneapi/compiler/2022.0.2/linux/compiler/lib/intel64_lin/libimf.a /Intel/Linux/oneapi/compiler/2022.0.2/linux/compiler/lib/intel64_lin/libirc.a /Intel/Linux/oneapi/compiler/2022.0.2/linux/compiler/lib/intel64_lin/libifport.a /Intel/Linux/oneapi/compiler/2022.0.2/linux/compiler/lib/intel64_lin/libsvml.a /Intel/Linux/oneapi/compiler/2022.0.2/linux/compiler/lib/intel64_lin/libirng.a /lib/x86_64-linux-gnu/libc-2.31.so /usr/lib/x86_64-linux-gnu/libc_nonshared.a /lib/x86_64-linux-gnu/libstdc++.so.6 -L /lib/x86_64-linux-gnu -L /usr/lib/gcc/x86_64-linux-gnu/9 -Wl,--start-group /Intel/Linux/oneapi/mkl/2022.0.2/lib/intel64/libmkl_intel_lp64.a /Intel/Linux/oneapi/mkl/2022.0.2/lib/intel64/libmkl_sequential.a /Intel/Linux/oneapi/mkl/2022.0.2/lib/intel64/libmkl_core.a -Wl,--end-group -Wl,--start-group /Intel/Linux/oneapi/mkl/2022.0.2/lib/intel64/libmkl_intel_lp64.a /Intel/Linux/oneapi/mkl/2022.0.2/lib/intel64/libmkl_sequential.a /Intel/Linux/oneapi/mkl/2022.0.2/lib/intel64/libmkl_core.a -Wl,--end-group -lpthread -ldl -lm
Thanks, Ron
mecej4
Thanks for the detailed information as to the link line. Why is "fmslib.a fmsint.a" repeated four times, and "yesgpu.a" two times?
Other than that, I cannot see anything unusual. Although the repetitions many not be needed, they should have cause the linking to fail.
I second the suggestion that you post this problem report in the MKL Forum.
Multipath
Thanks for looking at this.
What is the link to the MKL Forum?
The libraries are repeated because there may be circular references that need to be resolved.  Probably too many times.
Note that if I simply add
-qmkl=sequential
to the link line it works
ls -al MatrixWarrior_dbg -rwxrwxr-x 1 ron ron 134192944 Mar 14 07:19 MatrixWarrior_dbg
ldd MatrixWarrior_dbg
linux-vdso.so.1 (0x00007fffeedfa000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f8326566000)
libmkl_intel_lp64.so.2 => /Intel/Linux/oneapi/mkl/2022.0.2/lib/intel64/libmkl_intel_lp64.so.2 (0x00007f83256c6000) libmkl_sequential.so.2 => /Intel/Linux/oneapi/mkl/2022.0.2/lib/intel64/libmkl_sequential.so.2 (0x00007f8323cac000)
libmkl_core.so.2 => /Intel/Linux/oneapi/mkl/2022.0.2/lib/intel64/libmkl_core.so.2 (0x00007f831f8f5000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f831f8eb000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f831f6f9000) libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f831f517000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f831f4f4000) libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f831f3a5000) /lib64/ld-linux-x86-64.so.2 (0x00007f8326588000) libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f831f388000)
but it uses the shared object version of MKL.
Multipath
I noticed that your last response did include a hyperlink to the MKL Form so I posted the question there.
Thanks for your help.
Roin
