29488 Discussions
Open MPI wrapper compiler unable to find ifort
Juhan_Matthias_K_
I'm trying to install a piece of computational software that makes use of open mpi for parallel execution (following these instructions http://www.crystal.unito.it/Manuals/crystal14_P.pdf). When I enter the terminal command
sudo make parallel
I get the following output:
mkdir -p ../bin/Linux-ifort_XE_emt64/v1.0.4
mkdir -p ../obj
/opt/openmpi-ifort-1.6.5/bin/mpif90 -c -FR  -O3 -align -i-static -cxxlib -I./Includes -I../obj -module ../obj -o ../obj/libmultitask_MPI.o libmultitask_MPI.f90
The Open MPI wrapper compiler was unable to find the specified compiler
ifort in your PATH.
Note that this compiler was either specified at configure time or in
one of several possible environment variables.
Makefile:177: recipe for target '../obj/libmultitask_MPI.o' failed
make: *** [../obj/libmultitask_MPI.o] Error 1
when I run in the terminal
printenv PATH
the first environment variable is
/opt/intel/composer_xe_2013_sp1.2.144/bin/intel64
and this folder contains the ifort compiler.
ifort -h
then ifort the ifort help is displayed.
Does anyone have any suggestions for why I am getting the error "The Open MPI wrapper compiler was unable to find the specified compiler
ifort in your PATH." and how to fix it?
TimP
You must setup ifort by sourcing the compilervars script or alternate means your sysadmin may have chosen.
Izaak_Beekman
New Contributor II
On HPC systems often this is something like `module load intel/17` or similar.
Juhan_Matthias_K_
Thanks for the help... I was able to sort this out.
pDs
Hello Juhan!
How were you able to resolve this?
