Open unicode filename
Clayton_Evans
Microsoft uses unicode filenames in NTFS.  http://msdn.microsoft.com/en-us/library/windows/desktop/dd317748%28v=vs.85%29.aspx
My attempts to open a file with a unicode name have proven unsuccessful. I am passing the unicode in from C++, when the program comes to the open statement is fails with a file not found.  If I force the C++ to convert the filename to ANSI characters, it works.  With the Unicode name being passed, I have tried doubling the length of the string being passed to the Fotran from the C++.  The results show below are from this case.
        OPEN ( UNIT =  IOINP, FILE = INFILE, ACTION = 'READ',  FORM = 'FORMATTED', IOSTAT = IOS, ERR = 998 )
  998 CONTINUE
      WRITE (16, *) 'IOS = ', IOS, LEN ( INFILE ), INFILE
The output looks like
 IOS =           29          42 B a k k e n   H o r i z o n t a l . d a t
The intell help file states: "The name can be any pathname allowed by the operating system.  Any trailing blanks in the name are ignored."
My experience indicates that the Intel Fortran statement only accepts ANSI characters, Microsoft documentation states that MS uses Unicode file names.  In countries which use a unicode character set, how does one use the Intel Fortran OPEN statement?
Clayton Evans
Anonymous66
Valued Contributor I
You are correct that the compiler does not support unicode. We do support multibyte characters though. You can use MBConvertUnicodeToMB to convert the unicode file name to multibyte.
Clayton_Evans
So if one has a filename with Unicode characters, Intel Fortran cannot open the file.  Correct?
Anonymous66
Correct, unless it is converted to multibyte.
IanH
You could also open the file using the USEROPEN extension and the underlying CreateFileW api.
