I've successfully started using OpenGL with CVF by including a "use dfopngl" statement. However, I can't use quadrics (cylinders, disks, etc.). I get no errors, I just don't see the picture I'm after. The functions I'm using are fgluNewQuadric and fgluCylinder etc.
Cheers,
Sam Howman
Cheers,
Sam Howman
I havent used quadrics but if your intention is to draw cyliders, cubes and cones etc you can use
or some of the built in primitves in the library (you can print out the dfopngl.f90 file and go through all the built in libraries).
However, what I typically do for complex shapes like is call Vertex3f(x,y,z) and draw lines with a glBegin(GL_LINE_STRIP) (for wireframes) and or glBegin(GL_QUAD_STRIP) (for solids). This way you can draw cubes, cones whatever.
Norman Lawrence's book has a number of these examples and it might be helpful for you to look into that.
Hope this helps.
Sumit
call fauxWireCylinder(radius,height) or call fauxSolidCylinder(radius,height)
Hope this helps.
Sumit
