The Final Committee Draft (FCD) of the next standard for Fortran has
entered its public comment phase. The document is available from
http://www.j3-fortran.org. Click on "J3 documents" in the panel on the
left, and then on "Current Working Draft Standard for Fortran 2003 (single
document in PDF format)" in the center of the page. It is also available
from ftp://ftp.j3-fortran.org/j3/doc/standing/007 as PostScript, plain
text or LaTeX, and from http://www.dkuug.dk/jtc1/sc22/open/n3661.pdf. It
may also be helpful to read "The new features of Fortran 2003", which
is available from ftp://ftp.nag.co.uk/sc22wg5/N1551-N1600/N1579.pdf.
At this stage, comments about editorial issues are most likely to result
in changes to the published Standard. Recommendations to add or remove
features will most likely not gather sufficient support to result in
substantive changes in this revision of the Standard.
Comments are brought to the ISO IEC/JTC1/SC22/WG5 international Fortran
committee by way of national bodies. The United States national body is
the United States Technical Advisory Group (US TAG) for Fortran, which
consists of US members of the ANSI/INCITS J3 Fortran committee.
The US TAG solicits comment on the FCD from US residents and citizens,
and employees or representatives of US-domiciled corporations. Please
submit Comment to j3@j3-fortran.org no later than noon EST on Thursday 6
November 2003. This deadline is dictated by the schedule of J3 meetings.
The next J3 meeting is 10-14 November; the one after that is after the
deadline for national bodies to submit comment to the international
committee.
Comments other than US comment should be directed to the respective
national bodies. Each national body may have a different deadline. The
list of ISO member bodies may be found at
http://www.iso.ch/iso/en/aboutiso/isomembers/MemberList.MemberSummary?MEMBERCODE=10
This message was originally sent to the comp-fortran-90@jiscmail.ac.uk list
and the comp.lang.fortran news group. Please forward or cross-post it to
any other lists by which you believe it would reach interested parties.
Van Snyder | What fraction of Americans believe
Van.Snyder@jpl.nasa.gov | Wrestling is real and NASA is fake?
International Representative, ANSI/INCITS/J3 Fortran committee
Any alleged opinions are my own and have not been approved or disapproved
by JPL, CalTech, NASA, Sean O'Keefe, George Bush, the Pope, or anybody else.
committee.
I'm assuming that Intel plans to update its Fortran compiler to comply with the new standard if and when it is approved. Is that correct?
Does anyone have a feel for how long it will take for the 200x standard to be approved and adopted? Is it still many months away? Once that happens, roughly how long would it take Intel to issue an update?
Mike
Mike
At present, we have not committed to implementing everything in the standard once it is approved. I would expect that at first we will implement selected features from the standard, but Fortran 2003 is big, with many concepts that are new to Fortran. I've heard it said that it's even bigger than the change from F77 to F90, and that transition took 2-4 years for most commercial vendors.
Steve
Steve
