OpenMP and ISO_C_BINDING
Ed_M_
I have a fortran program that is parallelised using OpenMP. The main function calls a Fortran function that contains the definition of a system with Ordinary Differential Equations. This runs okay when split across different threads. I also want the option to link in a C file with similar definition for the ODE's, and I can get this to run when I don't use OpenMP. The ODE is calculated incorrectly though when using OpenMP.
!************* Main Program OpenMP part **************
!SETUPBV contains a function that contains the ODE
!definition
!$OMP PARALLEL DEFAULT(SHARED) PRIVATE(I,IT,NT)
      IT = 0
!$    IT = OMP_GET_THREAD_NUM()
      NT = 1
!$    NT = OMP_GET_NUM_THREADS()
      IF(NLLV>=0.OR.IFST==1) &
        CALL SETUBV(NDIM,NA,NCOL,NINT,NFPR,NRC,NROW,NCLM,                &
         FUNI,ICNI,AP,PAR,NPAR,ICP,A,B,C,DD(1,1,BASE+1),DUPS,            &
         FCFC(1,BASE+1),UPS,UOLDPS,RLOLD,UDOTPS,UPOLDP,DTM,THU,          &
         IFST,IAM,IT,NT,IRF,ICF,IID,NLLV)
      I = (IT*NA+NT-1)/NT+1
      CALL BRBD(A(1,1,I),B(1,1,I),C(1,1,I),D,DD,DUPS(1,(I-1)*NCOL),FAA,FC,&
        FCFC,P0,P1,IFST,IID,NLLV,DET,NDIM,NTST,NA,NBC,NROW,NCLM,         &
        NFPR,NFC,A1,A2,BB,CC,C2,CDBC,                                    &
        SOL,S1,S2,IPR,IPC,IRF(1,I),ICF(1,I),IAM,KWT,IT,NT)
!$OMP END PARALLEL
!************* Extract from Module containing INTERFACE definition **************
SUBROUTINE FUNCINTFC(NDIM,U,ICP,PAR,IJAC,F,DFDU,DFDP) BIND(C,NAME='func')
   USE, INTRINSIC :: ISO_C_BINDING
   INTEGER(C_INT), INTENT(IN) :: NDIM, IJAC, ICP(*)
   REAL(C_DOUBLE), INTENT(IN), VALUE :: U(NDIM), PAR(*)
   REAL(C_DOUBLE), INTENT(OUT), VALUE :: F(NDIM)
   REAL(C_DOUBLE), INTENT(INOUT) :: DFDU(NDIM,NDIM),DFDP(NDIM,*)
END SUBROUTINE FUNCINTFC
!************* Function calling c-function with ODE **************
SUBROUTINE FUNC(NDIM,U,ICP,PAR,IJAC,F,DFDU,DFDP)
  USE INTERFACES, ONLY: FUNCINTFC
  IMPLICIT NONE
  INTEGER, INTENT(IN) :: NDIM, IJAC, ICP(*)
  DOUBLE PRECISION, INTENT(IN) :: U(NDIM), PAR(*)
  DOUBLE PRECISION, INTENT(OUT) :: F(NDIM)
  DOUBLE PRECISION, INTENT(INOUT) :: DFDU(NDIM,*), DFDP(NDIM,*)
  CALL FUNCINTFC(NDIM,U,ICP,PAR,IJAC,F,DFDU,DFDP)
END SUBROUTINE FUNC
!************* C-function containing ODE definition **************
int func(integer *ndim, const doublereal u, const integer *icp,
               const doublereal par, const integer *ijac,
               doublereal f, doublereal *dfdu, doublereal *dfdp)
    /* Builtin functions */
    double exp(doublereal);
    /* Local variables */
    static doublereal e, u1, u2;
/* Evaluates the algebraic equations or ODE right hand side */
/* Input arguments : */
/*      NDIM   :   Dimension of the ODE system */
/*      U      :   State variables */
/*      ICP    :   Array indicating the free parameter(s) */
/*      PAR    :   Equation parameters */
/* Values to be returned : */
/*      F      :   ODE right hand side values */
/* Normally unused Jacobian arguments : IJAC, DFDU, DFDP (see manual) */
    /* Function Body */
    u1 = u[0];
    u2 = u[1];
    e = exp(u2);
    f[0] = -u1 + par[0] * (1 - u1) * e;
    f[1] = -u2 + par[0] * par[1] * (1 - u1) * e - par[2] * u2;
    return 0;
} /* func_ */
jimdempseyatthecove
Your C function has:
Remove the "static". The consequences of "static" inside the scope of a function (or other scope) is somewhat equivilent to Fortran's SAVE attribute. IOW one copy is stored in a static area that is not on stack, meaning the last value on exit of scope is valid on entry of scope. Think of this as shared(e,u1,u2).
Jim Dempsey
Ed_M_
Thank you. That did the trick. :-)
