OpenMP bug?
Piergiorgio_Alotto
Hi!
the following program segfaults after being compiled with ifort -openmp (v. 11.1) on both macs and Linux
program test
implicit none
integer,allocatable,dimension(:)::ivar
integer i,itot
allocate(ivar(5000))
itot=0
!$omp parallel do default(none) private(ivar) shared(itot)
do i=1,5000
ivar(i)=i
!$omp atomic
itot=itot+ivar(i)
enddo
!$omp end parallel do
deallocate(ivar)
write(6,*) itot
end
the same works if compiled with gfortran and pgi.
Any ideas?
Pier
Piergiorgio_Alotto
Dear Kevin,
I am running under Mac OS X 10.6.5
ifort -V -openmp test.f90
Intel Fortran Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20100203 Package ID: m_cprof_p_11.1.084
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
Intel Fortran 11.1-2692
export OMP_NUM_THREADS=2
./a.out
allocated 0 -1
allocated 0 0
allocated 0 0
allocated 1 0
allocated 1 1
so the Mac version appears to be older in date (20100203) but newer in version (084) with respect to Linux...
I will try to upgrade and see if the problem persists
Thanks a lot for having investigated the matter!
Kevin_D_Intel
Thank you for the clarification. I confirmed it produces incorrect results on Mac OS X 10.4.x with Xcode 3.2.2 andifort 11.1.084 and that it also appears fixed in ifort 11.1.089.
I also confirmed this is not related to the ifort/icc and Xcode 3.2.2 linker compatibility issue and that -use-asm has no effect. Reproducing this on Linux also confirms that. It appears there was perhaps an OpenMP defect with ifort from what I see. Ido nothave a specific internal report that I can relate the behavior to.
If you can upgrade to at least ifort 11.1.089, I believe that should resolve the issue.
Confirmed the test case behaves with 11.1.089:
$ ifort -V -openmp u78716.f90
Intel Fortran Intel 64 Compiler Professional for applications running on Intel 64, Version 11.1 Build 20100806 Package ID: m_cprof_p_11.1.089
Intel Fortran 11.1-2755
@(#)PROGRAM:ld PROJECT:ld64-97.2
$ export OMP_NUM_THREADS=2
$ OMP_NUM_THREADS=2
$ ./a.out
allocated 0 -1
allocated 0 0
allocated 0 0
allocated 1 -1
allocated 1 1
15
jimdempseyatthecove
>>if the list item is allocated, the new list item will have an initial state of allocated
Correct, I simply provided a reproducer that showed more detail regarding the problem.
Regarding "unable to use reduction" (should be posted as a different thread)
It would be nice if the OpenMP standard has (maybe it does have) a means to determine the iteration control variables. The purpose being to be able to determin: first iteration, last iteration, number of iterations (or stride).
!$omp parallel do
do i=iFrom, iTo, iStep
The current specification makes variable i local to the parallel region
I am suggesting that it would be nice if the programmer could determine theslices equivilent to the iFrom, iTo
Since many loops use literal constants a declaration of some sort needs to be provided
**** pseudo code with new feature recommendation
!$omp parallel do doprivate(iFrom, iTo) ...
do i=1,100
! i is currently private and has iteration point for this thread
! iFrom is private and has iteration start for this thread
! iTo is private and has iteration endfor this thread
if(i .eq. iTo) then
!$omp critical
!$omp end critical
endif
end do
Note, by providing a new type of private, you can also determine the iteration pointat any nest level (assuming variables of those nest levels are visible).
Jim Dempsey
Kevin_D_Intel
For the record, there was an earlier report of this issue opened with Development (internal tracking id noted below) that was fixed in the 11.1 update 7 (11.1.089 - Mac OS, 11.1.073 - Linux)
(Internal tracking id: DPD200150643)
