OpenMP compile error
reinaldogarcia
When I recompile my OpenMP code in the new version 11 I get this error:
1>: catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
1>in file C:\MODELS\SHAL2D_Xi_NG_Original\SHAL2D_HYDRO.F90, line 285, column 10
The piece of code where the error happens is this:
!$OMP PARALLEL PRIVATE(U_AM) ! this is line 285
!$OMP DO
DO K = 1, NNODOS
U_AM = 1./ AM(K)
UN(K) = UM(K) * U_AM
VN(K) = VM(K) * U_AM
ETAN(K) = EM(K) * U_AM
ENDDO ! K
!$OMP END DO
!$OMP END PARALLEL
The program was compiling fine in version 10.1. I checked the project properties and options are the same as in version 10.1.
Can someone help?
Reinaldo
Can you attach a small but complete sample that gets the error? If not, please submit a problem report to Intel Premier Support and provide the program there.
reinaldogarcia
Steve:
This is the subroutine where the error happens.
R
SUBROUTINE
FEM_SWE(NNODOS, NELEM, UN, VN, ETAN, U, V, ETA, &
AM, DTT, NODO, X, Y, AREA, H, T, EPSILON, XNMAN, MANNINGN)
! IN:
! NNODOS, NELEM, UM, VM, EM, U, V, ETA,
! DTT, NODO, X, Y, AREA, ETAN, H, AM, EPSILON, XNMAN
! LOCALS:
! SU, SV, SE
! UM, VM, EM
! OUT:
! UN, VN, ETAN
USE DFPORT
USE IFPORT
USE OMP_LIB
USE GLOBALSHAL2D
IMPLICIT NONE
INTEGER(4), INTENT(IN) :: NNODOS, NELEM
INTEGER(4), INTENT(IN) :: NODO(:,:)
REAL(8), INTENT(IN) :: DTT, T
REAL(8), INTENT(IN) :: EPSILON, XNMAN
REAL(8), INTENT(IN) :: AM(:)
REAL(8), INTENT(IN) :: X(:),Y(:)
REAL(8), INTENT(IN) :: AREA(:)
REAL(8), INTENT(INOUT) :: U(:), V(:), ETA(:), H(:)
REAL(8), INTENT(INOUT) :: UN(:),VN(:), ETAN(:)
REAL(8), INTENT(IN) :: MANNINGN(:)
REAL(8) :: UM(NNODOS), VM(NNODOS), EM(NNODOS)
REAL(8) :: SU(3), SV(3), SE(3) ! VECTORES ELEMENTALES PARA U, V, ETA
REAL(8) :: UME, DIAG, XNMAN2, DT24, AREA12, G6
REAL(8) :: B1, B2, B3, C1, C2, C3, E1, E2, E3
REAL(8) :: U1, U2, U3, V1, V2, V3, H1, H2, H3
REAL(8) :: UBAR, VBAR, HBAR, ARG, BDT, CDT
REAL(8) :: FACT, XFRIC_0, XFRIC_1, XFRIC_2, YFRIC_0, YFRIC_1, YFRIC_2
REAL(8) :: BIUI, CIUI, BIVI, CIVI, BIEI, CIEI, BIHI, CIHI, BUCV
REAL(8) :: G, U_AM
REAL(8) :: CV, GAMMAM, VISCDIN, ALFA1, BETA1, TY, ALFA2, BETA2
REAL(8) :: KF, SY, SVS, STD
real(8) :: rainfall, area3, rain, evap
INTEGER(4) :: I1, I2, I3, K, IM, IR, J, test
UM(1:NNODOS) = 0.
VM(1:NNODOS) = 0.
EM(1:NNODOS) = 0.
! SELECTIVE LUMPING
UME = 1. - EPSILON
DIAG = 2. * (EPSILON + 1.)
!XNMAN2 = XNMAN**2. ! RGM
DT24 = DTT/24.
G6 = 1.6333333 ! G / 6.
IF (IRAIN .EQ. 1) THEN
!determine rainfall and evaporation for time t!
call rainevapsource (t, rain, evap)
rainfall = (rain-evap)/1000./86400. ! daily (rainfall-evaporation) (mm/day) / (1000mm/m) / 86400 (s/day)
ELSE
RAINFALL = 0.
ENDIF
!$OMP PARALLEL PRIVATE(XNMAN2,I1,I2,I3,B1,B2,B3,C1,C2,C3,E1,E2,E3,AREA12,area3,UBAR,VBAR,HBAR,SU,SV,SE,IM,IR,ARG,FACT,XFRIC_0,XFRIC_1,XFRIC_2,YFRIC_0,YFRIC_1,YFRIC_2,BIUI,CIUI,BIEI,U1,U2,U3,BDT,BIVI,CIVI,CIEI,V1,V2,V3,CDT,H1,H2,H3,BIHI,CIHI,BUCV)
!$OMP DO REDUCTION(+:UM,VM,EM)
DO K = 1, NELEM
XNMAN2 = MANNINGN(K)**2.
I1 = NODO(K,1)
I2 = NODO(K,2)
I3 = NODO(K,3)
B1 = Y(I2) - Y(I3)
B2 = Y(I3) - Y(I1)
B3 = Y(I1) - Y(I2)
C1 = X(I3) - X(I2)
C2 = X(I1) - X(I3)
C3 = X(I2) - X(I1)
! FRICTION TERM
E1 = ETA(I1) + H(I1)
E2 = ETA(I2) + H(I2)
E3 = ETA(I3) + H(I3)
AREA12 = AREA(K) / 12.
area3 = area(k) /3.
UBAR = (U(I1) + U(I2) + U(I3)) / 3.
VBAR = (V(I1) + V(I2) + V(I3)) / 3.
HBAR = (E1 + E2 + E3) / 3.
!!!!!!!!!! ELIMINATE DRY ELEMENTS [du/dt] = F = 0 !!!!!!!!!
!!!!!!!!!! NG 03/22/07
!test =1
If((E1 <= 0.01 .and. E2 <= 0.01 .and. E3 <= 0.01)) THEN ! .AND. TEST .EQ.1) then
! VELOCIDAD U
SU(1) = ( 4*U(I1)) * AREA12
SU(2) = ( 4*U(I2)) * AREA12
SU(3) = ( 4*U(I3)) * AREA12
! VELOCIDAD V
SV(1) = ( 4*V(I1)) * AREA12
SV(2) = ( 4*V(I2)) * AREA12
SV(3) = ( 4*V(I3)) * AREA12
! ELEVACIN ETA
SE(1) = ( 4*ETA(I1)) * AREA12
SE(2) = ( 4*ETA(I2)) * AREA12
SE(3) = ( 4*ETA(I3)) * AREA12
DO IM = 1, 3 ! DISTRIBUYE A LOS NODOS LAS CONTRIBUCIONES DE ELEMENTO K
IR = NODO(K,IM)
UM(IR) = UM(IR) + SU(IM)
VM(IR) = VM(IR) + SV(IM)
EM(IR) = EM(IR) + SE(IM)
ENDDO ! IM
!!!!!!!! NG aadido 03/22/07 Aqui termina la subrutina que elimina los elementos secos del calculo hidrodinmico
else
ARG = UBAR**2 + VBAR**2
IF (HBAR .GT. 0.05 .AND. ARG .GE. 0.) THEN ! RGM
! ESTOS PARAMETROS SE DEFINEN EN LA TABLA 2 DE LA REFERENCIA
! O'BRIEN, J. & JULIEN, P.Y.
! LABORATORY ANALYSIS OF MUDFLOW PROPERTIES
! J. HYD. ENG. ASCE. VOL. 114. NO.8 , AUG. 1988
!FACT = XNMAN2 * 9.81 * SQRT(ARG) / (HBAR**(4./3.))
G = 9.81
! CV = 0.20 ! VOLUMETRIC SEDIMENT CONCENTRATION
! GAMMAM = 1200. ! SPECIFIC WEIGHT
! ALFA1 = 3.02E-4 !5E-2
! BETA1 = 33.1 !0.1
! ALFA2 = 1.72E-3/98. ! 4.
! BETA2 = 29.5 !0.1
! VISCDIN = ALFA1 * EXP(BETA1 * CV) ! DINAMIC VISCOSITY
! TY = ALFA2 * EXP(BETA2 * CV) ! YIELD STRESS
! KF = 25.0 ! RESISTENCE PARAMETER = 24 FOR LAMINAR FLOW
! SY = G * TY / ( GAMMAM * HBAR) ! YIELD SLOPE
! SVS = G * KF * VISCDIN / ( 8. * GAMMAM * HBAR**2.) ! VISCOUS SLOPE
FACT = XNMAN2 * G * SQRT(ARG) / (HBAR**(4./3.)) ! TURBULENT DISPERSIVE SLOPE
!FACT = STD !+ SVS !OJO RGM
!SY = 0.0
ELSE
! WRITE(*,*) 'TIME K, HBAR, ARG = ', T, K, HBAR, ARG
FACT = 0.01
!SY = 0.0
ENDIF
FACT = FACT * AREA12
XFRIC_0 = FACT * ( 2*U(I1) + U(I2) + U(I3))! + SY * AREA12
XFRIC_1 = FACT * ( U(I1) + 2*U(I2) + U(I3))! + SY * AREA12
XFRIC_2 = FACT * ( U(I1) + U(I2) + 2*U(I3))! + SY * AREA12
YFRIC_0 = FACT * ( 2*V(I1) + V(I2) + V(I3))! + SY * AREA12
YFRIC_1 = FACT * ( V(I1) + 2*V(I2) + V(I3))! + SY * AREA12
YFRIC_2 = FACT * ( V(I1) + V(I2) + 2*V(I3))! + SY * AREA12
!FACT = AREA12 * G * XNMAN2* 4.
!XFRIC_0 = FACT *U(I1) * SQRT(U(I1)**2+V(I1)**2)/(ETA(I1)+H(I1))**(4./3.)
!XFRIC_1 = FACT *U(I2) * SQRT(U(I2)**2+V(I2)**2)/(ETA(I2)+H(I2))**(4./3.)
!XFRIC_2 = FACT *U(I3) * SQRT(U(I3)**2+V(I3)**2)/(ETA(I3)+H(I3))**(4./3.)
!YFRIC_0 = FACT *V(I1) * SQRT(U(I1)**2+V(I1)**2)/(ETA(I1)+H(I1))**(4./3.)
!YFRIC_1 = FACT *V(I2) * SQRT(U(I2)**2+V(I2)**2)/(ETA(I2)+H(I2))**(4./3.)
!YFRIC_2 = FACT *V(I3) * SQRT(U(I3)**2+V(I3)**2)/(ETA(I3)+H(I3))**(4./3.)
! VELOCIDAD U
BIUI = B1*UN(I1) + B2*UN(I2) + B3*UN(I3)
CIUI = C1*UN(I1) + C2*UN(I2) + C3*UN(I3)
BIEI = (B1*ETAN(I1) + B2*ETAN(I2) + B3*ETAN(I3))*G6
U1 = UN(I1)*BIUI + VN(I1)*CIUI
U2 = UN(I2)*BIUI + VN(I2)*CIUI
U3 = UN(I3)*BIUI + VN(I3)*CIUI
BDT = DTT * BIEI
SU(1) = ( DIAG*U(I1)+ UME*U(I2)+ UME*U(I3)) * AREA12 - DT24 * (2*U1 + U2 + U3)- BDT -DTT *XFRIC_0
SU(2) = ( UME*U(I1)+ DIAG*U(I2)+ UME*U(I3)) * AREA12 - DT24 * ( U1 + 2*U2 + U3)- BDT -DTT *XFRIC_1
SU(3) = ( UME*U(I1)+ UME*U(I2)+ DIAG*U(I3)) * AREA12 - DT24 * ( U1 + U2 + 2*U3)- BDT -DTT *XFRIC_2
! VELOCIDAD V
BIVI = B1*VN(I1) + B2*VN(I2) + B3*VN(I3)
CIVI = C1*VN(I1) + C2*VN(I2) + C3*VN(I3)
CIEI = (C1*ETAN(I1) + C2*ETAN(I2) + C3*ETAN(I3)) * G6
V1 = UN(I1)*BIVI + VN(I1)*CIVI
V2 = UN(I2)*BIVI + VN(I2)*CIVI
V3 = UN(I3)*BIVI + VN(I3)*CIVI
CDT = DTT * CIEI
SV(1) = ( DIAG*V(I1)+ UME*V(I2) + UME*V(I3)) * AREA12 - DT24 * (2*V1 + V2 + V3)- CDT-DTT *YFRIC_0
SV(2) = ( UME*V(I1)+ DIAG*V(I2) + UME*V(I3)) * AREA12 - DT24 * ( V1 + 2*V2 + V3)- CDT-DTT *YFRIC_1
SV(3) = ( UME*V(I1)+ UME*V(I2) + DIAG*V(I3)) * AREA12 - DT24 * ( V1 + V2 + 2*V3)- CDT-DTT *YFRIC_2
! ELEVACIN ETA
H1 = ETAN(I1) + H(I1)
H2 = ETAN(I2) + H(I2)
H3 = ETAN(I3) + H(I3)
BIHI = B1*H1 + B2*H2 + B3*H3
CIHI = C1*H1 + C2*H2 + C3*H3
BUCV = BIUI + CIVI
E1 = UN(I1)*BIHI + VN(I1)*CIHI + H1*BUCV
E2 = UN(I2)*BIHI + VN(I2)*CIHI + H2*BUCV
E3 = UN(I3)*BIHI + VN(I3)*CIHI + H3*BUCV
SE(1) = (DIAG*ETA(I1) + UME*ETA(I2) + UME*ETA(I3)) * AREA12- DT24 * (2*E1 + E2 + E3) + rainfall*area3*dtt
SE(2) = ( UME*ETA(I1) + DIAG*ETA(I2) + UME*ETA(I3)) * AREA12 - DT24 * ( E1 + 2*E2 + E3) + rainfall*area3*dtt
SE(3) = ( UME*ETA(I1) + UME*ETA(I2) + DIAG*ETA(I3)) * AREA12 - DT24 * ( E1 + E2 + 2*E3) + rainfall*area3*dtt
IR = NODO(K,IM)
ENDDO ! IM
endif !NG aadido 03/12/07
ENDDO ! K (LAZO SOBRE TODOS LOS ELEMENTOS)
!$OMP END DO
!$OMP END PARALLEL
! $OMP PARALLEL PRIVATE(U_AM)
! $OMP DO
DO K = 1, NNODOS
U_AM = 1./ AM(K)
ENDDO ! K
! $OMP END DO
! $OMP END PARALLEL
END SUBROUTINE FEM_SWE
So far, I am unable to reproduce the problem. You did not supply the source of the module GLOBALSHAL2D so I made up my own with a declaration of IRAIN. What is the exact compile command line used?
Hint: When posting code here, please use the "Pencil" tool in the toolbar for best formatting.
reinaldogarcia
[cpp]MODULE GLOBALSHAL2D
   INTEGER(4) :: VERSIONNUMBER, IRAIN, ISED, IXSEC, IPROFILE, NMSTEPS, IVARDT, IINITIAL
   INTEGER(4) :: IODAT, IOTBA, IOFED, IOIFL, IOUVH, IOUVHE, IOOUT, IOOUTE, IOHHH, IOHHHE, IODVT
   INTEGER(4) ::  IOREP, IOXSEC, IOXSECE, IOPRF, IOPRFI, IOPRFE, IOUVHB, IOVTP, IOTXT, IOSED, IORET
   INTEGER(4) :: IOOPENB, IOCLSDB, IOBC
   INTEGER(4) :: IOPLT
   REAL(8) :: INITIALTIME
END MODULE GLOBALSHAL2D[/cpp]
OK. THanks. THe GLOBALSHAL2D is irrelevant. You can comment it out as well as the if block tha uses IRAIN. I did it and the problem persists. Anyway it is included above.
The command line is:
/nologo /O3 /Qparallel /Qopenmp /warn:interfaces /iface:cvf /module:"Release/" /object:"Release/" /libs:qwin /winapp /4Yportlib /c
Reinaldo
reinaldogarcia
Quoting - reinaldo.garcia
   INTEGER(4) :: IOPLT
Reinaldo
Steve:
Maybe this helps.Bellow is the full message that I get when compiling the file. Note that lines 76 appears to have been processed before the error message.
Thanks again,
Reinaldo
Compiling with Intel Fortran 11.0.061 [IA-32]...
ifort /nologo /O3 /Qparallel /Qopt-prefetch=1 /Qopenmp /warn:interfaces /iface:cvf /module:"Release/" /object:"Release/" /libs:qwin /winapp /4Yportlib /c /Qvc8 /Qlocation,link,"C:Program FilesMicrosoft Visual Studio 8VCbin" "C:MODELSSHAL2D_XiSHAL2D_HYDRO.F90"
C:MODELSSHAL2D_XiSHAL2D_HYDRO.F90(78): (col. 8) remark: OpenMP DEFINED LOOP WAS PARALLELIZED.
C:MODELSSHAL2D_XiSHAL2D_HYDRO.F90(76): (col. 7) remark: OpenMP DEFINED REGION WAS PARALLELIZED.
C:MODELSSHAL2D_XiSHAL2D_HYDRO.F90(55): (col. 4) remark: FUSED LOOP WAS VECTORIZED0_1631
in file C:MODELSSHAL2D_XiSHAL2D_HYDRO.F90, line 76, column 7
compilation aborted for C:MODELSSHAL2D_XiSHAL2D_HYDRO.F90 (code 3)
SHAL2D - 1 error(s), 0 warning(s)
Thanks - I can reproduce it now. Removing /iface:cvf eliminates the error. Do you really need that? Also, I see you have both /parallel and /Qopenmp. I'd suggest removing /parallel.
reinaldogarcia
Steve:
Thanks for finding this. I need /iface:cvf for a graphic library I use. Is there a workaround? Was there a change from version 10.1?
Reinaodo
Not a deliberate change. You have encountered a bug - anytime you get an error of the nature you did it's a compiler bug.
My preferred solution would be to write a module with a series of interface blocks for the graphics routines that require CVF conventions, adding the directive:
!DEC$ ATTRIBUTES STDCALL, REFERENCE, MIXED_STR_LEN_ARG, DECORATE, ALIAS:"ROUTINENAME" :: routinename
The name in the ALIAS needs to be uppercase.
If you do this and then USE the module, you won't need to compile the sources with /iface:cvf
reinaldogarcia
Steve:
Thanks! I will try that.
Reinaldo
This has been reported as issue DPD200110137.
reinaldogarcia
Steve, thanks.
reinaldogarcia
Steve:
Quick question. Is there a way I could follow up this issue? I would like to know when would it be resolved in a future compiler update.
Thnaks,
Reinaldo
You could open an issue with Intel Premier Support and reference the above report number. I would do it for you but I can't find you with the email address you have for the forum. I do see a fiu.edu address that looks as if it may be yours - is it? (Please don't post your actual email address here.)
reinaldogarcia
Steve:
I had reported the issue there, but I think they will appreciate your input. My email is [deleted]
Reinaldo
Ok, great. I found the issue and will make sure you are notified of updates.
