29285 Discussions
OpenMP fortran code seems to work but perhaps shouldn't
Vahid9
The following code gives identical output serially and with OpenMP (my first OpenMP code). I am trying to understand if this is pure luck or not. The code does not have CRITICAL or ATOMIC constructs. Should such constructs be used in this code to avoid data racing? The agreement between the serial and parallel versions suggests no data racing but I have a feeling that I am missing something here.
Are constructs such as CRITICAL or ATOMIC needed here?
Vahid
!       program SEE.f90
        use omp_lib
        implicit none
        INTEGER, PARAMETER :: DP = selected_real_kind(14,200)
        REAL(DP), PARAMETER :: zero   = 0.d0
        REAL(KIND=DP), parameter :: kb=8.6173324d-02 ! meV/K
        INTEGER, PARAMETER :: Nk=9936
        INTEGER, PARAMETER :: Nk_BZ=216000
        INTEGER, PARAMETER :: nbnd=4
        INTEGER ::  i,j,dummy,m,n, eqv(Nk_BZ)
        REAL(KIND=DP)    :: deltaE,tot_delta,delta, inv_tau_delta, tot_inv_tau_delta
        REAL(KIND=DP)    :: temp,  degaussw, E, kT
        REAL(KIND=DP), allocatable   :: SKE(:,:,:), ek(:,:)
        REAL(KIND=DP), allocatable    :: SEE(:,:)
        REAL, EXTERNAL :: w0gauss
        temp=300.0
        kT=kb*temp ! meV
        allocate (SKE(Nk,nbnd,0:3100))
        allocate (ek(Nk,nbnd))
        allocate (SEE(0:3100,0:3100))
        OPEN(10,file="SKE_new.dat")
        OPEN(15,file="EPW_scatt_rates.dat")
        OPEN(14,file="bz2wedge_k.dat")
        OPEN(20,file="SEE.dat")
        ! Skip header
        READ(10,*)
        READ(14,*)
        DO i=1,Nk
        DO j=1,nbnd
        DO m=0,3100
          READ(10,*) dummy,SKE(i,j,m)
        ENDDO
          READ(15,*) ek(i,j), dummy
        ENDDO
        ENDDO
        ! Read the mapping between loop index and eqv(i)
        DO i=1,Nk_BZ
          READ(14,*) dummy, eqv(i)
        ENDDO
        degaussw=0.01
        deltaE=1.0d-3
        SEE(:,:)=zero
             !$omp parallel do shared (SEE,degaussw,SKE,ek,eqv) private (i,j,n,m,E,delta,inv_tau_delta,tot_delta,tot_inv_tau_delta)
        DO m=0,3100
         DO n=0,3100
           tot_delta=zero
           tot_inv_tau_delta=zero
           E=n*DeltaE
              DO i=1,Nk_BZ
               DO j=1,nbnd
               delta = w0gauss((E-ek(eqv(i),j))/degaussw)/degaussw
               inv_tau_delta=SKE(eqv(i),j,m)*delta
               tot_delta=tot_delta+delta
               tot_inv_tau_delta=tot_inv_tau_delta+inv_tau_delta
               ENDDO ! j
              ENDDO ! i
              SEE(n,m)=tot_inv_tau_delta/tot_delta
          ENDDO ! n
         ENDDO ! m
        !$omp end parallel do
         DO n=0,3100
          DO m=0,3100
           WRITE(20,"(2I8,ES18.8E3)") n, m,  SEE(n,m)
          ENDDO ! n
         ENDDO ! m
         deallocate(SEE)
         deallocate(SKE)
         deallocate(ek)
         CLOSE(10)
         CLOSE(14)
         CLOSE(15)
         CLOSE(20)
    STOP
    END
FUNCTION w0gauss (x)
  IMPLICIT NONE
  REAL(DP), PARAMETER :: sqrtpi = 1.77245385090551602729_DP
  REAL(DP), PARAMETER :: sqrtpm1= 1.0_DP / sqrtpi
  REAL(DP) :: w0gauss, x, arg
  arg = min (200.d0, x**2)
  w0gauss = exp ( - arg) * sqrtpm1
  return
END FUNCTION
jimdempseyatthecove
Of the shared variables (SEE,degaussw,SKE,ek,eqv), only the array SEE is written to, .AND. one of its subscripts is the loop control variable of the parallel loop. Therefore, each thread writes to different locations (elements) of the array SEE. IOW, the parallel loop is thread safe.
The function w0gauss is also thread-safe.
Jim Dempsey
jimdempseyatthecove
Jim Dempsey
Vahid9
Thanks Jim. I now understand why the code works.
Best,
Vahid
