OpenMP version of WRF 3.6 core dump
An_Yang
Hi all,
Both single OpenMP and MPI OpenMP version of WRF3.6 core dump, but serial and MPI version works fine.
Do you thinks it's a bug in openmp?
My env:
CentOS6.5 with full updates, 64bits
Intel parallel_studio_xe_2013_sp1_update3
WRF3.6 compiled with icc
OpenMPI 1.6.5 compiled with icc
NetCDF 4.1.3 compiled with icc
test case: conus12km_data_v3
Hareware: Intel(R) Core(TM) i7-4710MQ CPU @ 2.50GHz, 8GB RAM
TimP
 Guessing that you may mean a segv abort, such as a stack overflow, which of the standard remedies did you investigate?
https://software.intel.com/en-us/articles/determining-root-cause-of-sigsegv-or-sigbus-errors
http://www.open-mpi.org/community/lists/users/
I note that Intel instructions, e.g.
https://software.intel.com/en-us/articles/wrf-and-wps-v311-installation-bkm-with-inter-compilers-and-intelr-mpi
imply using Intel MPI with default stack limits for both shell stack (e.g. ulimit -s) and thread stack (OMP_STACKSIZE),
but you may need to reconsider, particularly in view of your use of openmpi
I've heard suggestions from influential people that default stack limits ought to be increased, but nothing has changed, to my knowledge.
Remember that OMP_STACKSIZE defaults to 4MB with Intel 64-bit compilers.  If you double that, the shell stack size requirement increases by 4MB times number of threads.   So you would not arbitrarily use more threads than you would expect to be useful.
MPI ranks don't inherit shell stack size from the shell where you launch MPI, so you may need to launch a script under MPI which sets stack size, even though you will find expert recommendations to the contrary.
An_Yang
(gdb) bt
#0  0x00000000017e41c3 in module_diffusion_em_mp_compute_diff_metrics_ ()
#1  0x000000000104df15 in module_first_rk_step_part2_mp_first_rk_step_part2_ ()
#2  0x00002b5020b1ded3 in L_kmp_invoke_pass_parms () from /opt/intel/composer_xe_2013_sp1.3.174/compiler/lib/intel64/libiomp5.so
#3  0x00007ffedaf13d40 in ?? ()
#4  0x00007ffedaf13d48 in ?? ()
#5  0x00007ffedaf13d50 in ?? ()
#6  0x00007ffedaf13d58 in ?? ()
#7  0x00007ffedaf13d60 in ?? ()
#8  0x00007ffedaf13d68 in ?? ()
#9  0x00007ffedaf13d70 in ?? ()
#10 0x00007ffedaf13d78 in ?? ()
#11 0x00007ffedaf13d80 in ?? ()
#12 0x00007ffedaf13d88 in ?? ()
#13 0x00007ffedaf13e80 in ?? ()
#14 0x00007ffedaf13e88 in ?? ()
An_Yang
Thanks Tim,
OMP_STACKSIZE=8M works.
An_Yang
MPI version of WRF:
grep 'Timing for main' rsl.error.0000 | tail -150 | awk '{print $9}' | awk -f stats.awk
    items:       150
      max:         9.808480
      min:         4.432730
      sum:       758.022770
     mean:         5.053485
 mean/max:         0.515216
OpenMP version of WRF:
grep 'Timing for main' openmp.log | tail -150 | awk '{print $9}' | awk -f stats.awk
    items:       150
      max:         8.808800
      min:         4.216570
      sum:       724.733490
     mean:         4.831557
 mean/max:         0.548492
724.733490÷758.022770=95.6%,openmp version is a little bit faster than MPI version.
