OpenMP with associate - define private?
Johannes_Rieke
New Contributor III
Hi, I like to parallize a loop with OpenMP. For better readability I further like to use associate within this loop. In a minimum working example this looks like:
program OMP_associate
  use iso_fortran_env, only : compiler_version
  implicit none
  integer :: i, i_dummy(73), i_array(42,73)
  write(*,'("OMP with associate test")')
  write(*,'("Compiler version: ",a)') compiler_version()
  i_array = 73
  !$OMP parallel do private(i, i_dummy)
  ! !$OMP parallel do private(i, i_dummy, i_ass) ! this is not accepted, because i_ass is not defined, has no type
  do i = 1, size(i_array,dim=2)
    associate (i_ass => i_array(:,i)) ! this causes a race condition, because i_ass is not declared as private
    ! do something
    i_dummy(i) = sum(i_ass)
    end associate
  end do
  !$OMP end parallel do
  write(*,'(*(i8))') i_dummy
end program OMP_associate
The code compiles with this option fine (PSXE 2020 initial, aka 19.1.0, Windows OS):
/nologo /debug:full /Od /Qopenmp-offload /Qopenmp /warn:all /debug-parameters:used /module:"x64\Debug\\" /object:"x64\Debug\\" /Fd"x64\Debug\vc150.pdb" /traceback /check:all /libs:static /threads /dbglibs /c
At run time it fails in line 25 with multiple threads because i_ass is not private and i_dummy contains garbadge. Single threaded works fine.
Compiler version: Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.0.166 Build 20191121
forrtl: error (63): output conversion error, unit -1, file CONOUT$
Image              PC                Routine            Line        Source
OMP_associate.exe  00007FF601019564  Unknown               Unknown  Unknown
OMP_associate.exe  00007FF601016683  Unknown               Unknown  Unknown
OMP_associate.exe  00007FF601013771  Unknown               Unknown  Unknown
OMP_associate.exe  00007FF60101133E  MAIN__                     25  OMP_associate.f90
OMP_associate.exe  00007FF6010AA47E  Unknown               Unknown  Unknown
OMP_associate.exe  00007FF6010AB194  Unknown               Unknown  Unknown
OMP_associate.exe  00007FF6010AB0BE  Unknown               Unknown  Unknown
OMP_associate.exe  00007FF6010AAF7E  Unknown               Unknown  Unknown
OMP_associate.exe  00007FF6010AB209  Unknown               Unknown  Unknown
KERNEL32.DLL       00007FFAD5A637E4  Unknown               Unknown  Unknown
ntdll.dll          00007FFAD85BCB81  Unknown               Unknown  Unknown
Is there a way to get the pointer associated to a variable private without using an explicitly defined pointer/target construct? Otherwise I would use a local copy...
jimdempseyatthecove
Try:
!$omp ...
do I=...
  block
    associate(i_ass=>...
  end block
end do
!$omp end...
or
  implicit none
  integer :: i, i_dummy(73)         ! *** remove i_array
  integer, target :: i_array(42,73) ! *** add i_array with TARGET attribute
  integer, pointer :: i_ass (:,:)      ! *** add pointer to rank 2 array
  i_array = 73
!$OMP parallel do private(i, i_dummy, i_ass) ! *** now declare pointer as private
    ! do something
    end associate
  end do
Jim Dempsey
Johannes_Rieke
New Contributor III
Hi Jim, thanks for your reply.
The second solution I've tried to avoid, because in my application I would have to assign many class components as targets. In your above second suggestion in line 7 it must say integer,pointer::i_ass(:), because of rank 1. Then it works fine.
However, I found a coding error of mine in the original code: In line 13 i_dummy must not be listed in the OMP private definition. Removing it, the original code runs fine although i_ass is not defined as private explicitly.
!$OMP parallel do private(i,i_dummy) !change to private(i)
The first solution of Jim would require to nest the associate within a block. Wasn't there recently a thread, where this causes problems (compiler implementation not standard)?
Are locally defined variables in blocks always treated as private in an OMP section?
Finally is this - automatically OMP private - valid for assoiated variables, too?
BR, Johannes
Johannes_Rieke
New Contributor III
UPDATE: What works fine in this simple example, fails in my complex application. I'll try to nail it down, but I'm highly suspicious for using associate within an OMP section for now. Using a block around it, fails in a different way.
While I'm working on a reproducer, has anyone knowledge, whether associate can be savely used within an OMP section? Does the standard mention something?
Mark_Lewy
Valued Contributor I
I've only just noticed this thread, but have encountered this problem too.
The OpenMP and Fortran standards are not explicit on what happens to an associate name inside an OpenMP parallel do loop and, as you note, you can't specify an associate name in a private clause.
I noticed data races in some OpenMP loops with associate blocks in 18.0.3 and 19.0.5; my work-around was to either use a local pointer or variable instead.  Another way to avoid this would be to refactor your loop body into a separate subroutine.
I thought I had reported this to Intel Support, but it doesn't look as if I have (probably couldn't find time to create a small reproducer near release time :-().
jimdempseyatthecove
IMHO
The associate-name should be defined in the context of the associate context of the thread encountering the associate. IOW, the associate name need not, and in fact shall not be referenced in an OMP directive. However, the current OpenMP implementation appears to require specification on DEFAULT(NONE)?
Note, as to if the selector of the associate-name is private or shared, this would depend on if the =>selector were the same or different amongst threads in the parallel region.
Jim Dempsey
Mark_Lewy
Thanks Jim,
I think I agree with what you have said.  My interpretation of OpenMP 5.1 is that it requires the selector to be specified for default(none), but still makes no mention of associate-name.  I'm tempted to post a question on the OpenMP forum to see if there is a definitive answer.
My view is also that the associate-name should be treated as private to the thread, but my experience of current versions of Intel Fortran suggest this is not the case.
I also wonder whether it's worth me creating a small reproduce for Intel Support?
Mark
jimdempseyatthecove
I think the OpenMP forum is the better place. If you get an authoritative answer to this, that conflicts with the implementation, it will carry more weight to affect a change.
Jim Dempsey
jimdempseyatthecove
You may also consider passing the array slice to a contained procedure (or external procedure) that is called by each thread.
Jim Dempsey
Johannes_Rieke
New Contributor III
Hi Jim, yes that would be an idea.
I now figured out, what went wrong. In my application I made a similar mistake as in the original example. I put an array defined and allocated outside the OMP section into the private list. This caused some wierd errors and was misleading me to associated pointer. Once I got an array bounds error of a variable with the associated pointer, then an access violation in libiomp5md.dll and thirdly an error while deallocating a complete other variable - all with only slightly changing the order of some lines. I suggest that by the OMP private statement local copies have been made and that these could not be correctly finalized in OMP lib/during compilation. For sure a mistake of my own.
I wonder, if it would be possible to make the compiler identifying this error and give the user a warning?
Nevertheless, the question, whether an ASSOCIATE statement can be savely used within an OMP section, is still open. It seems to work with the Intel compiler, but might not with other compilers.
jimdempseyatthecove
For allocatable arrays that are not allocated outside the parallel region, that are to be allocated (and deallocated) within the parallel region, use FIRSTPRIVATE as opposed to PRIVATE. I know for a fact that at least older versions of the compiler used to result in the (supposed) unallocated array descriptor initially containing junk inside the parallel region. I am not sure if this was corrected. The use of FIRSTPRIVATE copies in the unallocated state of the array descriptor.
Jim Dempsey
