OpenMP
siemer_michael
HI,
how do I get openmp to work in xcode 3.1 ? I have the most recent intel fortran and it's running fine without openmp.
If I choose enable openMP support in the build settings I get the following error message:
dyld: Library not loaded: libiomp5.dylib
Referenced from: /Users/.../Library/Developer/Xcode/DerivedData/hello_world-gboojatjcgugwggnwsmnsuruvbam/Build/Products/Debug/hello world
Reason: image not found
thanks a lot.
Michael
zuch
Hi Michael,
You need to setDYLD_LIBRARY_PATHenvironment variable in the Xcode environment.
You can find more details here
siemer_michael
Thanks, after fixing that I still get the following error message:
sharedlibrary apply-load-rules all
Warning: the current language does not match this frame.
No memory available to program now: unsafe to call malloc
warning: Attempting to create USE_BLOCK_IN_FRAME variable with block that isn't in the frame.
Current language: auto; currently fortran
Any ideas what to do about this one?
