Scratch files
maria
I have a very simple question about openning scratch files. I am using IVF 9.0.
I have some scratch files opened during the run. I thought that these files would be deleted automatically
after the runis completed. But theyare not. I then have to use a CLOSE statement with STATUS = '
DELETE' todelete the scratch files.
Something wong with my coding? My open and close statements are attached. Thanks.
DO N=1,M
IFILE=IC+NC(N)
OPEN (UNIT=IFILE, FORM='UNFORMATTED', STATUS='SCRATCH', ERR=95)
ENDDO
DO N=1, M
IFILE=IC+NC(N)
CLOSE(IFILE,STATUS='DELETE')
ENDDO
lklawrie
Have you tried just closing them? According to my reference, if you close them, then they will automatically be deleted, but if you don't issue a CLOSE on them, they may stay around.
Anonymous66
Valued Contributor I
The scratch files should be deleted when the program terminates.In both9.0 and the latest version of the compiler, the scratch file is being deleted for the simple program below:
[fortran]program test OPEN (UNIT=5, FORM='UNFORMATTED', STATUS='SCRATCH' ) write(5,IOSTAT=IO_STATUS) "Hello" !close(5) end program test [/fortran]
Can you share an example program where the scratch file is not being deleted?
