OpenMPI 1.10.0 built with Intel Parallel Studio XE 2016
Fabrice_Roy
I have built Open MPI 1.10.0 using Intel compilers 16.0.0.
When I am trying to compile the following test code:
  program testmpi
    use mpi
    implicit none
    integer :: pid
    integer :: ierr
    integer :: tok
    call mpi_init(ierr)
    call mpi_comm_rank(mpi_comm_world, pid,ierr)
    if(pid==0) then
       tok = 1
    else
       tok = 0
    end if
    call mpi_bcast(tok,1,mpi_integer,0,mpi_comm_world,ierr)
    call mpi_finalize(ierr)
  end program testmpi
I get the following error message:
testmpi.f90(21): error #6285: There is no matching specific subroutine for this generic subroutine call.   [MPI_BCAST]
compilation aborted for testmpi.f90 (code 1)
The compilation and execution succeed if I declare tok as
integer, dimension(1) :: tok
I have also built Open MPI 1.10.0 with GNU 5.2.0 compilers and both versions of the test code (with tok declared as an integer or as an integer, dimension(1) ) compile and execute.
Open MPI was configured with the same options with both compilers.
Do you have any idea how I could solve this problem?
Fabrice Roy
TimP
As far as I can see, this is simply a matter of ifort requiring standards compliant source code. Openmpi interface correctly specifies an array argument. Although you are running on a platform where the hardware doesn't distinguish an array of length 1 from a scalar, there are platforms where this would fail even if the compiler let it slip by.  As you're probably aware, another option is to use the array constructor [tok] which should do the right thing for each platform.
Fabrice_Roy
Thanks for your answer.
If I understand correctly what you are writing and what I have read in the MPI norm, using a scalar as a sending buffer should not have worked previously. Am I right?
This seems to be a new behaviour for ifort 16. OpenMPI built with ifort 15 does not behave the same way.
I suppose ifort 16 is working the way it is intended to work and I have to modify my code using the array constructor.
Thanks again.
TimP
The scalar could work on Intel platforms as long as the compiler allowed the standards violation to slip by.
Jeff_Squyres
The issue is that Intel Parallel Studio 2016 changed to partially -- but not completely -- support the !GCC$ pragma for ignore TKR.
Specifically, Open MPI's configure script tests whether the Fortran compiler supports the !GCC$ pragma or not.  Prior to the 2016 version, the Intel Parallel Studio ifort compiler (correctly) failed this test, and Open MPI (correctly) fell back to using the !DEC$ pragma for ignore-TKR behavior.  With the 2016 version, the configure test for !GCC$ in Open MPI v1.10.0 passes, but the !GCC$ pragma doesn't actually work (at least in the way that Open MPI uses it).  Meaning: Open MPI compiles the "mpi" module, but all MPI interfaces with a choice buffer (such as MPI_BARRIER) don't actually adhere to the ignore-TKR behavior, and therefore you get a compile failure when you try to compile your test program.
We've made the configure test in Open MPI more stringent so that Intel Parallel Studio 2016's pseudo-!GCC$-support now fails the test, and configure correctly falls back to !DEC$.  Although this updated test will be in 1.10.x nightly snapshot tarballs (http://www.open-mpi.org/nightly/v1.10/) very soon, it'll still take a little time before we are able to get an official release out of Open MPI 1.10.1 (which will contain this fix).
