For 8.1 version of ifort it was recommended to use -O3 -xW keys for
generation of codes for Opteron CPUs.
In 9.0 there are new optimization "-x keys" plus new Opteron's work w/SSE3.
What are now the best ("in common case") optimization keysfor Opteron?
Mikhail Kuzminsky
Zelinsky Institute of Organic Chemistry
Moscow
If you will be running on Opteron only, the same advice applies: -xW. If you will also be running on Intel processors with Intel EM64T, then use -xW -axP with our EM64T compiler.
