29487 Discussions
Optimized and non-optimized executables give different results
Yaqi_Wang
I met this problem in my project and able to identify it with a shorter version.
I compiled the following codewith IVF 11.1.065 twice.
One is with,
/nologo /debug:full /Od /gen-interfaces /warn:interfaces /module:"Debug\\\\" /object:"Debug\\\\" /traceback /check:bounds /libs:static /threads /dbglibs /c
(copied from VS property pages.)
another is with,
/nologo /O3 /Qipo /module:"Release\\\\" /object:"Release\\\\" /libs:static /threads /c
The code has four files.
File 1: the main
program test
use Quadrilateral1
implicit none
call INIT_QUADRILATERAL1()
print *, quadrilateral1_rtcsr(-1)%ia, quadrilateral1_rtcsr(-1)%ja, quadrilateral1_rtcsr(-1)%a
stop
end program test
File 2: some constant definitions
MODULE DataKind
INTEGER, PARAMETER :: RKD = 8
INTEGER, PARAMETER :: NLEN = 4 ! length of default integers
INTEGER, PARAMETER :: RLEN = 8 ! length of RKD reals
INTEGER, PARAMETER :: PLEN = 32 ! pointer length
REAL(RKD), PARAMETER :: zero = 0.0_RKD
REAL(RKD), PARAMETER :: one = 1.0_RKD
END MODULE DataKind
File 3: a sparse-matrix utility module
MODULE SparseMatrix
USE DataKind
IMPLICIT NONE
!> Compressed Sparse Row format\\n
!! Note: non-zeros are sorted by their column indices in each row.
TYPE CSR
INTEGER :: n !< number of rows
INTEGER :: m !< number of columns
INTEGER :: nnz !< number of non-zeros
INTEGER :: nnz_capacity !< capacity of non-zeros
INTEGER :: mcount=5*NLEN+3*PLEN !< memory count in bytes
INTEGER, POINTER :: ia(:) =>null() !< (n+1) pointers to the beginning of each row of all non-zeros
INTEGER, POINTER :: ja(:) =>null() !< (nnz_capacity) column index of all non-zeros
REAL(RKD), POINTER :: a(:) =>null() !< (nnz_capacity) non-zeros
END TYPE CSR
CONTAINS
!> Create a zero CSR matrix\\n
!! Note: if the matrix exists, this operation reiniializes the matrix. Old matrix will be erased.
!! n, m being equal to zero is allowed.
SUBROUTINE csr_init(a, n, m, nnz_capacity)
IMPLICIT NONE
TYPE(CSR) :: a
INTEGER :: n, m
INTEGER, OPTIONAL :: nnz_capacity
INTEGER :: nnz, istat, i
a%mcount = 5*NLEN + 3*PLEN
IF (ASSOCIATED(a%ia)) THEN
DEALLOCATE(a%ia, STAT=istat)
IF (istat/=0) STOP
ENDIF
ALLOCATE(a%ia(n+1), STAT=istat)
IF (istat/=0) STOP
a%mcount = a%mcount + (n+1)*NLEN
IF (PRESENT(nnz_capacity)) THEN
nnz = nnz_capacity
ELSE
nnz = 0
ENDIF
IF (ASSOCIATED(a%ja)) THEN
DEALLOCATE(a%ja, STAT=istat)
IF (istat/=0) STOP
ENDIF
ALLOCATE(a%ja(nnz), STAT=istat)
IF (istat/=0) STOP
a%mcount = a%mcount + nnz*NLEN
IF (ASSOCIATED(a%a)) THEN
DEALLOCATE(a%a, STAT=istat)
IF (istat/=0) STOP
ENDIF
ALLOCATE(a%a(nnz), STAT=istat)
IF (istat/=0) STOP
a%mcount = a%mcount + nnz*RLEN
a%n = n
a%m = m
a%nnz = 0
a%nnz_capacity = nnz
DO i = 1, a%n+1
a%ia(i) = 1
ENDDO
DO i = 1, a%nnz_capacity
a%ja(i) = 0
a%a(i) = zero
ENDDO
RETURN
END SUBROUTINE csr_init
!> Create identity matrix in a
SUBROUTINE csr_identity(n, a)
IMPLICIT NONE
INTEGER :: n ! dimension
TYPE(CSR) :: a ! identity matrix
INTEGER :: i
CALL csr_init(a, n, n, n)
a%nnz = n
DO i = 1, n
a%ia(i) = i
a%ja(i) = i
a%a(i) = one
ENDDO
a%ia(n+1) = n+1
RETURN
END SUBROUTINE csr_identity
END MODULE SparseMatrix
File 4: another module using sparse-matrix module
MODULE Quadrilateral1
USE DataKind
USE SparseMatrix
INTEGER, PARAMETER :: quadrilateral1_pmax = 7 ! maximum polynomial order
INTEGER, PARAMETER :: quadrilateral1_maxndofs = (quadrilateral1_pmax+1)*(quadrilateral1_pmax+2)/2
INTEGER, PARAMETER, PRIVATE :: rotm1(quadrilateral1_maxndofs) = &
(/ 1, &
-1, 1, &
1,-1, 1, &
-1, 1,-1, 1, &
1,-1, 1,-1, 1, &
-1, 1,-1, 1,-1, 1, &
1,-1, 1,-1, 1,-1, 1, &
-1, 1,-1, 1,-1, 1,-1, 1 /)
TYPE(CSR), SAVE :: quadrilateral1_rtcsr(-1:1)
CONTAINS
!> Initialize quadrilateral module
SUBROUTINE INIT_QUADRILATERAL1()
IMPLICIT NONE
INTEGER :: i
! Set up the rotation matrix
CALL csr_identity(quadrilateral1_maxndofs, quadrilateral1_rtcsr(1))
CALL csr_identity(quadrilateral1_maxndofs, quadrilateral1_rtcsr(-1))
DO i = 1, quadrilateral1_maxndofs
quadrilateral1_rtcsr(-1)%a(i) = quadrilateral1_rtcsr(-1)%a(i) * rotm1(i)
ENDDO
RETURN
END SUBROUTINE INIT_QUADRILATERAL1
END MODULE Quadrilateral1
The results in non-optimized mode:
1 2 3 4 5 6
7 8 9 10 11 12
13 14 15 16 17 18
19 20 21 22 23 24
25 26 27 28 29 30
31 32 33 34 35 36
37 1 2 3 4 5
6 7 8 9 10 11
12 13 14 15 16 17
18 19 20 21 22 23
24 25 26 27 28 29
30 31 32 33 34 35
36 1.00000000000000 -1.00000000000000
1.00000000000000 1.00000000000000 -1.00000000000000
1.00000000000000 -1.00000000000000 1.00000000000000
-1.00000000000000 1.00000000000000 1.00000000000000
-1.00000000000000 1.00000000000000 -1.00000000000000
1.00000000000000
which are the one I expected.
Results with the optimized version,
1 2 3 4 5 6
7 8 9 10 11 12
13 14 15 16 17 18
19 20 21 22 23 24
25 26 27 28 29 30
31 32 33 34 35 36
37 1 2 3 4 5
6 7 8 9 10 11
12 13 14 15 16 17
18 19 20 21 22 23
24 25 26 27 28 29
30 31 32 33 34 35
36 1.00000000000000 1.00000000000000
1.00000000000000
They are different. So what is going wrong?
Yaqi_Wang
From the optimization options, I do either of following, the error is gone.
1. add 'quadrilateral1_rtcsr(-1)%ia = quadrilateral1_rtcsr(-1)%ia' after csr_identity is called;
2. turn on /check:pointer;
3. turn on /check:bounds.
mecej4
This appears to be an optimizer bug. It can also be observed with the 32-bit version of the recently released 11.1.067 version of the Windows compiler, and on the 32-bit 11.1.073 compiler on Linux-x64. However, if the optimization level is reduced to /O2, the bug goes away.
The bug is not seen with corresponding Intel64 versions (11.1.073 on Linux, 11.1.067 on Windows-64).
Kevin_D_Intel
mecej4 posted a smaller reproducer(here). I will keep this thread updated accordingly with new information about this issue as I learn it.
