Optional argument confusion when using '-standard-semantics'
Bálint_A_
Dear all,
It seems to me that ifort 16.0.3 has some difficulties with optional argument passing, when using the -standard-semantics option. The code below demonstrates the issue. The present() query in the subroutine returns false, although the actual argument is an allocated pointer. Changing the dummy argument to be an assumed-shape array cures the problem, the same way as leaving away the -standard-semantics option does it as well.
Bálint
module bugtestmod
  implicit none
contains
  subroutine optarg(array)
    real, intent(in), optional :: array(3,3)
    print *, 'PRESENT?', present(array)
  end subroutine optarg
end module bugtestmod
program bugtest
  use bugtestmod
  implicit none
  real, pointer :: array(:,:)
  allocate(array(3,3))
  array(:,:) = 1.0
  call optarg(array)
end program bugtest
Steven_L_Intel1
Very interesting. I can reproduce this and we'll investigate.
Steven_L_Intel1
The specific option that triggers the problem is -fpscomp logicals, which is implied by -standard-semantics. It's not PRESENT that is the issue but rather the argument is being passed incorrectly, causing PRESENT to fail (and also the dummy argument to be unusable.) Why -fpscomp logicals should have such an effect, I have no idea, and I have asked the developers to figure it out. Issue ID is DPD200412406.
If you want a workaround, add -fpscomp nologicals.
Bálint_A_
Indeed an interesting cross-effect. Dear Steve, thank you for your fast response and workaround suggestion.
Bálint
Steven_L_Intel1
This problem has been fixed. I think the fix will be in the 17.0 product release.
Steven_L_Intel1
The fix should also appear in 16.0.4.
