I found an interesting segfault that I'm hesitant to call a bug because I don't know what the standard has to say about it, but I think it should work.
Consider the following program:
For scalars, this works correctly. However, for arrays, it segfaults. I'm sure it is because an array pointer is more than just a memory address as recently discussed here.
For what it's worth, this works as expected (both print statements are FALSE) for XLF, PGI, Cray, Pathscale, and Gfortran. But, I'm not sure what the standard says, so it may be a "feature" and not a "bug."
In the mean time, we just always pass in arrays for the array arguments to avoid the segfault.
Thoughts?
Tim
[fortran]PROGRAM myTest
IMPLICIT NONE
INTEGER, POINTER :: scalarPtr
INTEGER, DIMENSION(:), POINTER :: arrayPtr
CALL SetScalar(scalarPtr)
PRINT *, ASSOCIATED(scalarPtr)
CALL SetArray(arrayPtr)
PRINT *, ASSOCIATED(arrayPtr)
CONTAINS
SUBROUTINE SetScalar(a,b)
IMPLICIT NONE
INTEGER, POINTER :: a
INTEGER, INTENT(IN), TARGET, OPTIONAL :: b
a => b
END SUBROUTINE SetScalar
SUBROUTINE SetArray(a,b)
IMPLICIT NONE
INTEGER, DIMENSION(:), INTENT(IN), TARGET, OPTIONAL :: b
a => b
END SUBROUTINE SetArray
END PROGRAM myTest[/fortran] This is a simple example -- in our real case, it would be far too expensive to put IF(PRESENT()) around the arguments. We were hoping that if no argument is passed for the OPTIONAL dummy arguments, that the pointer would just point to NULL() and report back that it is not associated.For scalars, this works correctly. However, for arrays, it segfaults. I'm sure it is because an array pointer is more than just a memory address as recently discussed here.
Thoughts?
Tim
Article 12.4.1.6 of the F2003 standard says:
A dummy argument that is not optional shall be present. An optional dummy
31 argument that is not present is subject to the following restrictions:
32 (1) If it is a data object, it shall not be referenced or be defined.
Your code violates this on line-20 and line-29, if b is not present and is referenced. Therefore, your statements "works correctly" and "works as expected" are unsupported by the standard.
