29376 Discussions
Output file naming in incremental order
sashi_balakrishnan
I am am calculating pressure distribution (say 50 by 50 matrix)on a surface for each time step. I would like to save the pressure values for each of the time step as text but would like the name tocorrespond to the time step, e.g. "pressure_t1.txt","pressure_t2.txt" etc. Can you please help me solve this problem? Thanking you in advance.
ArturGuzik
Valued Contributor I
I'm not sure this is waht you want, but you can use "internal write" inside your loop (over time steps). Something like this below (not tested, just idea)
character (len=8) :: string
character (len=256) :: step_name, name
name='..../pressure_t_'
do i=1, max_steps
string=''
! internal write
WRITE (FMT='(I8)', UNIT=string, IOSTAT=stat_val) i
! check status
IF (stat_val /= 0) THEN
! handle error
END IF
! count blank(s) trailing
bl=scan(string(1:len_trim(string)), ' ', back=.true.)
! concatenate
step_name=name(1:len_trim(name))//string(bl+1:len_trim(string))//'.dat'
! open file with step_name
! calculations
! close file
end do
A.
Les_Neilson
Valued Contributor II
Quoting - arturguzik
! internal write
You could also use a format of "(i0)" which will automatically remove leading spaces and then you can concatenate string directly.
One problem with this method is sorting of the file names (a directory listing or file explorer), itwill give all of the t1* files first ie t1, t10,t11,t12... then t2,t20,t21 etc)
A way round this is to write leading zeros to string. For example : If you know that you will have less than 1000 steps then you can use a format of (i3.3) when writing to string. This will give you t001, t002, t003 etc.
If you don't know directly the magnitude of the number of steps then youwould write some code to work out what the (In.n) format should be, based on the value of (your)max_steps.
Les
sashi_balakrishnan
Quoting - les_neilson
Les
Gentlemen,
Thank you both for your replies. I have managed to combine the suggestions and come up with the following code to achieve what I wanted to do!
CHARACTER(20) sFileName
WRITE(sFileName, "(A, i3.3, A)") 'pressure', ntime_count, '.txt'
open(101,file=sFileName)
write(101,906)((pressure(i,j),j=1,nyy ),i=1,nxx)
906 format (21(EN12.0),1X)
I really appreciated both your help.
Sashi
Sashi
