29488 Discussions
Overwritten variables with Ifort for mac
leonardogual
Dear all,
I have a problem programming with ifort.
I cut out all parts of the program not giving problems, so now there is an elementary program
still giving the problem, and I don't understand why.
If I write the file "prova.f" as
implicit none
real*8 z(4)
z(1) = 1.d0
z(2) = 1.d0
z(3) = 1.d0
z(4) = 1.d1
print*,z(1)
write(*,101)z(1)
101 format(d16.10)
stop
end
and compile is as
ifort prova.f
./a.out
the output is
1.626021063200095E-260
0.1626021063-259
It seems that the variable z(1) has been note stored correctly, and overwritten!
If instead I complile it with
gfortran prova.f
./a.out
or with
ifort prova.f -debug -all
./a.out
the output is correct, i.e.
1.00000000000000
0.1000000000D+01
Which is the problem?
Thanks!
Leonardo
mecej4
You did not state which version of the compiler you used. See if this sticky note at the top of the forum applies to your installation and, if so, try the stated work-around:
Xcode 3.2.2 and 3.2.3 not supported and may cause errors
leonardogual
Thanks! My version of Xcode is 3.2.4 and of ifort it is 11.1 20090511,
so the problem is that one explained in your link.
I added -use-asm and it works prefectly.
Leonardo
Kevin_D_Intel
Hi Leonardo,
Glad the work-around worked for you. Your 11.1 compiler is the original 11.1 release which is fairly dated so you might consider upgrading your compiler at some point too.
There are options available to avoid this known linker/compiler incompatibility and upgrade the compiler:
1. Upgrade to the current 11.1 Update 7 (m_cprof_p_11.1.089 - Build 20100806)
2. Wait one week to upgrade to the 11.1 Update 8 (tentatively the week of 12/13/2010)
3. Upgrade now the new Intel Fortran Composer XE 2011 Update 1 release (m_fcompxe_2011.1.122 - if your support services are current)
4. Upgrade now to Xcode 3.2.5 (containing a new linker that is compatible with symbols produced by the Intel compilers). I recommend upgrading your Intel compiler first to at least the latest 11.1 update 7 or 8 (when available) when choosing this option.
