29651 Discussions
PARAMETER Variable - helps optimization?
neverwillreply
Does having compile-time constants that are labelled as "PARAMETER" help to compiler to optimize? For example, if there we have a
LOGICAL, PARAMETER :: testValue = .FALSE.
and then somewhere
IF (testValue) THEN
! Some code here
END IF
Can the compiler work out that no test is needed? In fact, does the compiler no even include the code "! Some code here".
Nym.
In many cases, yes. PARAMETER constants and literal constants are treated the same here.
neverwillreply
Ok. So if there is some code
IF (.FALSE.) THEN
! Some code
END IF
Would the compiler include or not include the "! Some code" in the output file? Would the above three line be essentially removed?
Nym
TimP
You could check this, for your own case, by compiling with -S, to see whether code corresponding to those source lines was eliminated. Most likely, this would be done in dead code elimination phases of the compiler (not at -O0).
