PARAMETER of Defined Type
Svein-Atle_Engeseth
Please see the following program
      MODULE TEST_CONSTRUCTOR
      IMPLICIT NONE
      TYPE :: ABC
        PRIVATE
        INTEGER :: I = 0
        REAL :: R = 0.0
        CONTAINS
        PROCEDURE, PUBLIC :: PRINTME
      END TYPE ABC
      INTERFACE ABC
        MODULE PROCEDURE INIT_ABC
      END INTERFACE
      TYPE (ABC), PARAMETER :: P = ABC(3, 4.0)
      PRIVATE
      PUBLIC :: ABC, P
      CONTAINS
      FUNCTION INIT_ABC(I, R) RESULT(RESULTAT)
        IMPLICIT NONE
        INTEGER, INTENT(IN) :: I
        REAL, INTENT(IN) :: R
        TYPE (ABC) :: RESULTAT
        RESULTAT % I = I
        RESULTAT % R = R
      END FUNCTION INIT_ABC
      SUBROUTINE PRINTME(X)
        IMPLICIT NONE
        CLASS(ABC), INTENT(IN) :: X
        WRITE(6,10) X % I, X % R
   10   FORMAT(/,1X,"I = ",I5,5X,"R = ",ES15.6)
      END SUBROUTINE PRINTME
      END MODULE TEST_CONSTRUCTOR
      PROGRAM TEST_CONSTRUCTOR_PGM
      USE, NON_INTRINSIC :: TEST_CONSTRUCTOR
      IMPLICIT NONE
  !    TYPE (ABC) :: A = ABC(3, 4.0) ! Uncomment this line and I get a compilation error when INTERFACE ABC is defined.
      ! Does this mean that it is impossible to have a statement like that shown below if ABC has private components?
  !    TYPE (ABC), PARAMETER :: Y = ABC(1, 1.0)
      TYPE (ABC) :: A
      TYPE (ABC) :: B
      B = ABC(5, 12.0)
      CALL A % PRINTME()
      CALL B % PRINTME()
      CALL P % PRINTME()
      END PROGRAM TEST_CONSTRUCTOR_PGM
The line TYPE(ABC) :: A = ABC(3, 4.0) isn't allowed because of private components.
So what do I do if I want to have a PARAMETER of derived type defined in a program, assuming I don't have access to the module?
Svein-Atle Engeseth
jimdempseyatthecove
What is the purpose of "I want to have a PARAMETER of derived type defined in a program"?
A reason that I can think of is to effectively make the variable (Y) Read-Only. Is this what you intend?
If so, consider making an encapsulating type, containing a private instance of ABC (as Y), and supplying the appropriate GET functions.
FWIW this could be a case for the Fortran committee to consider an attribute READONLY.
While you can use INTENT(IN) on a dummy argument, you cannot on a module variable.
Jim Dempsey
FortranFan
Svein-Atle Engeseth wrote:
.. The line TYPE(ABC) :: A = ABC(3, 4.0) isn't allowed because of private components. ..
The issue is not about private components of the derived type, especially because the code includes an INTERFACE with the same name as the derived type with a MODULE PROCEDURE to what is effecitvely a type constructor.  Rahter, it has to do with what the Fortran standard stipulates regarding the use of "constant expressions"  in a compile-time situation "to specify an initial value for an entity".  See this:
https://software.intel.com/en-us/fortran-compiler-18.0-developer-guide-and-reference-constant-expressions#8EE5286D-1A77-44E6-8AC8-BA11125DB053​
.. So what do I do if I want to have a PARAMETER of derived type defined in a program, assuming I don't have access to the module?. ..
It is unclear what this means, what is the desired coding need, particularly considering the "don't have access to the module" aspect.
Svein-Atle_Engeseth
Hi Jim,
The thought was that an entity of a user defined type could have the attribute PARAMETER just like an entity of intrinsic type.
Fortranfan,
By not having access to the module I mean I am not allowed to change it's content.
So if I want to have a variable of type ABC with the PARAMETER attribute I will have to specify that in the program, not in the module.
And I want the type ABC to have private components.
Svein-Atle
