29345 Discussions
PARAMETER show up as an "uninitialized variable" at execution time...
Richard_M_1
I have a piece of code that can (loosely) be considered to look as follows:
INTEGER*4 mgrd
PARAMETER (mgrd=50_4)
IF (i.gt.mgrd) THEN
END IF
When debugging this and asking the compiler to check initialization state at run time, it considers mgrd to be an uninitialized variable and not a run-time constant. I'm deducing this since the debugger breaks on the if statement and the only thing that actually doesn't have a value is mgrd.
Bug? or feature?
Dick Munroe
How about showing a whole program that demonstrates the problem. It isn't the PARAMETER.
