29649 Discussions
PASS attribute and parameterized derived types
Olsen__Oystein
I get the following error when I compile pass_pdt.f90 (attached):
pass_pdt.f90(28): error #8262: For a type-bound procedure that has the PASS binding attribute, the first dummy argument must have the same declared type as the type being defined.   [VAL]
  SUBROUTINE testq(val, this)
I explicitly attach the pass attribute to the second argument, this, and not the first. The second attached file (pass.f90) has no such issues. The only difference is that the derived type is no longer parameterized. Is this a compiler bug?
This is with ifort version 15.0.2, on openSUSE 13.2.
Øystein
Seems likely it's a compiler bug. I will send this on to the developers. Thanks.
FortranFan
"Is this a compiler bug?" - I think so, in the PDT implementation.
Issue ID is DPD200366416
Fixed in a release later this year.
Nicolas_Essis-Breton
Is this fixed in 15.0.3?
The attached file gives the same error with
ifort lc_types.f90 -I./  -c -g  -traceback -gen-interfaces  -warn all -check all -fpe0 -ftrapuv -I/opt/intel/composer_xe_2015.3.187/mkl/include
No - it will be fixed in 16.0.
