29654 Discussions
Coarray - Internal compiler error / Wrong results
Jan_W_2
Compiling this program with ifort version 15.0.1 gives me:
testarray.f90: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
compilation aborted for testarray.f90 (code 1)
Here is the code:
module test
  implicit none
  contains
  function sum_assumedshape(input, length) result(output)
   complex, dimension(:), intent(in)  :: input
  •    complex            :: output
       integer, intent(in) :: length
       integer :: i
       output = cmplx(0.0, 0.0)
       do i = 1, length
          output = output + input(i)
       end do
      end function
      function sum_assumedsize(input, length) result(output)
       complex, dimension(length), intent(inout)  :: input
  •    complex                     :: output
       integer :: i
       do i = 1, length
       end do
      end function
    end module
  • program sizevsshape
      use test
      implicit none
      complex, allocatable, dimension(:) :: in[:]
      complex                            :: out
      integer  :: i
      integer, parameter :: length = 4
      allocate(in(length)
      in = (/(cmplx(real(i),0.0), i=1, length)/)
      if(this_image() == 1) write(*,*) in
      out = sum_assumedshape(in, length)
      if(this_image() == 1) write(*,*) out
      out = sum_assumedsize(in, length)
  •   if(this_image() == 1) write(*,*) out
    end program
    When I compile this with ifort 14. it works but the assumed size function
    gives me a wrong result.
    Thank you
    Jan
    The internal compiler error is gone in 15.0.3, but the wrong results remain. However, the 16.0 beta works fine,so it looks as if this has already been fixed.
    Jan_W_2
    Oh ok!
    Thank you!
