29280 Discussions
Invoking constructor of abstract base class in Fortran
Paul_Levold
I originally posted this question on Stackoverflow (http://stackoverflow.com/questions/30823756/invoking-constructor-of-abstract-base-class-in-fortrant), but perhaps the Intel community har more knowledge on this topic?
Consider one of the classic OOP examples (see source code at the end of the post):
  • Abstract base class Shape
  • Class Rectangle extending Shape
I have two questions:
  1. In the source code below I've tried to define a constructor for the abstract class Shape using class(Shape), pointer :: this as result without ever allocating the pointer. Is this the correct way of defining a constructor for an abstract class in Fortran?
  2. How can I invoke the constructor of the base class (Shape) in the constructor of the extending class (Rectangle)? Using this%Shape = Shape(xCenter, yCenter) works for non-abstract base classes, but both the Intel compiler and gfortran gives me errors when the result type is class(Shape), pointer (required for an abstract class).
module Shape_mod
    implicit none
    private
    public Shape
    type, abstract :: Shape
        private
        double precision :: centerPoint(2)
    contains
        procedure :: getCenterPoint
        procedure(getArea), deferred :: getArea
    end type Shape
    interface Shape
        module procedure constructor
    end interface Shape
    abstract interface
        function getArea(this) result(area)
            import
            class(Shape), intent(in) :: this
            double precision :: area
        end function getArea
    end interface
contains
    !Correct way of defining a constructor for an abstract class?
    function constructor(xCenter, yCenter) result(this)
        double precision, intent(in) :: xCenter
        double precision, intent(in) :: yCenter
        print *, "constructing base shape"
        this%centerPoint = [xCenter, yCenter]
    end function constructor
    function getCenterPoint(this) result(point)
        double precision point(2)
        point = this%centerPoint
    end function getCenterPoint
end module Shape_mod
module Rectangle_mod
    use Shape_mod
    implicit none
    private
    public Rectangle
    type, extends(Shape) :: Rectangle
        private
        double precision :: length
        double precision :: width
    contains
        procedure :: getArea
    end type Rectangle
    interface Rectangle
    end interface Rectangle
contains
    function constructor(length, width, xCenter, yCenter) result(this)
        type(Rectangle), pointer :: this
        double precision :: xCenter
        double precision :: yCenter
        print *, "Constructing rectangle"
        allocate(this)
        this%length = length
        this%width = width
        !How to invoke the base class constructor here?
        !The line below works for non-abstract base classes where the
        !constructor result can be type(Shape)
        class(Rectangle), intent(in) :: this
        area = this%length * this%width
end module Rectangle_mod
program main
    use Rectangle_mod
    implicit none
    type(Rectangle) :: r
    r = Rectangle(4.0d0, 3.0d0, 0.0d0, 2.0d0)
    print *, "Rectangle with center point", r%getCenterPoint(), " has area ", r%getArea()
end program main
FortranFan
You may want to post this on comp.lang.fortran to get an even broader perspective on OO design patterns with Fortran.  In addition, you may want to consult the books mentioned by Dr Fortran on his blog, especially the one by Rouson et al. on Scientific Software Design mentioned in the footnote.
Given Fortran's lack of "new" keyword similar to that in OO-centric languages and intricacies with type construction, my own preference is to use to simple methods that operate on classes (type-bound procedures in Fortran parlance, as you know very well) rather than constructors and in general, I try to avoid Fortran pointers (aliases) if I can, given all the complexities involving efficiency and optimization and proper clean up and in handling them in assignment contexts.  So my approach would fall along the lines below where the "generic" is made use of and expanded upon to "create" the class:
module kinds_mod
   use, intrinsic :: iso_fortran_env, only : r8 => real64
   private
   public :: r8
end module kinds_mod
module Shape_mod
   use kinds_mod, only : r8
   implicit none
   private
   type, abstract, public :: Shape
      private
      real(r8) :: centerPoint(2)
   contains
      private
      procedure, pass(this) :: ConstructShape
      procedure, pass(this), public                     :: getCenterPoint
      procedure(IgetArea), pass(this), deferred, public :: getArea
      generic, public :: Construct => ConstructShape
   end type Shape
   abstract interface
      function IgetArea(this) result(area)
         import :: Shape, r8
         real(r8) :: area
      end function IgetArea
   end interface
contains
   subroutine ConstructShape(this, xCenter, yCenter)
      class(Shape), intent(inout) :: this
      real(r8), intent(in) :: xCenter
      real(r8), intent(in) :: yCenter
      this%centerPoint = [ xCenter, yCenter ]
      return
   end subroutine ConstructShape
      real(r8) point(2)
      return
   use Shape_mod, only : Shape
   implicit none
   private
   type, extends(Shape), public :: Rectangle
      private
      real(r8) :: length
      real(r8) :: width
   contains
      private
      procedure, pass(this) :: ConstructRectangle
      procedure, pass(this), public :: getArea
      generic, public :: Construct => ConstructRectangle
   end type Rectangle
contains
   subroutine ConstructRectangle(this, length, width, xCenter, yCenter)
      class(Rectangle), intent(inout) :: this
      real(r8), intent(in) :: length
      real(r8), intent(in) :: width
      call this%Construct(xCenter=xCenter, yCenter=yCenter)  !.. Create the base class
      this%width = width
      return
   end subroutine ConstructRectangle
      real(r8) :: area
      return
program main
   use Rectangle_mod, only : Rectangle
   implicit none
   call r%Construct( length=4.0_r8, width=3.0_r8, xCenter=0.0_r8, yCenter=2.0_r8 )
   stop
end program main
Upon execution,
 Rectangle with center point 0.00000000000000 2.00000000000000  has area
 12.0000000000000
Press any key to continue . . .
You might notice a few other stylistic preferences; the above mentioned books offer multiple views on this matter.  But perhaps the important thing to note is "double precision" is deprecated in Fortran; you might find it helps to have a defined kind for floating-point types in portable code.
IanH
The basic answer to the OP's question is "use a subroutine to carry out the steps required to "construct" the parent object", along the lines of what FortranFan shows for the abstract parent class.
For the concrete extension class, it may be worth considering using a function.  With F2008 support this can simplify the code invoking the constructor (you can directly assign to a polymorphic allocatable object of declared type Shape, which might save having a temporary of declared type Rectangle), though it may come with the downside of some additional overhead associated with the "value copy" associated with assignment of the function result.  In Fortran 2003 you can simulate aspects of the Fortran 2008 behaviour (and work around some ifort 15 bugs...) using ALLOCATE(...SOURCE=constructor_function(xxx)).
For the subroutine case, there may be benefits to making the argument of the object to be constructed INTENT(OUT), though this does mean that you have invoke the procedure for the parent constructor before you define any components in the extension.  INTENT(OUT) gives guarantees about the state of default initialized and allocatable components, which can make subsequent construction logic simpler.
I'm in two minds about whether it is useful having these construction procedures as type bound procedures.  I don't think it makes sense to override them (perhaps I'm wrong??), so its just a bit of a namespace nicety (which is still nice) with the downside of the restrictions on passed arguments.
(Deprecation of double precision is a issue of style, it is not formally obsolescent in the current or draft next standard).
