29487 Discussions
Parallel Studio XE 2011 with VS 2010: Unable to use multiple cores and extra memory available for fast computation
Nikhil_L_
Hello all,
I am using Parallel Studio XE 2011 with VS 2010. I am trying to run one code with repetitive calculations. However, speed for entire computation is very slow. When I looked at CPU and memory usage it shows that half of the memory and CPU is not used. I tried to enable  Configuration Properties ->Fortran -> Optimization -> Parallelization -> Yes (/QParallel) and Optimization->Maximize Speed. But still no improvement in performance was observed. Diagnostics reports are as follows:
1><;-1:-1;PGO;;0>
1>      1 FUNCTIONS HAD VALID STATIC PROFILES
1>  IPO CURRENT  QUALITY METRIC:  50.0%
1>  IPO POSSIBLE QUALITY METRIC:  50.0%
1>  IPO QUALITY  METRIC RATIO:   100.0%
Can anybody help me to interpret this report and improve performance of my code?
What other options that I can try to speed up computations?
Please let me know,
Thank you,
Nik
