When I install it states that I am missing Microsoft Visual Studio 2010 C++ x64 Compiler and Tools components. I have installed .NET Framework 4 (including extended) and the 2010 SDK tools (including for Windows 7 (7.1)).
How do I get Intel Parallel Studio XE 2011 to recognize the existence of the components?
Note that your license for Parallel Studio XE includes access to Microsoft Visual Studio 2010 Shell and Libraries, provided by the Fortran install. I thought the Parallel Studio XE installer had that too, but if not, you can download Intel Visual Studio Composer XE 2011 - the installer that includes Visual Studio Shell. This will be usable for Fortran only, not C/C++.
Does this help?
I preinstalled (before Parallel Studio XE) .NET 4 and the SDK tools. maybe this was a mistake?
Thanks for the feedback!
The Fortran is a user subroutine which is linked to a larger piece of software I have no control of. They use the SDK tools to compile the user subroutine and spawn a linked executable. I did load Visual Studio Express (per their instructions):
http://www.microsoft.com/downloads/en/details.aspx?FamilyID=6b6c21d2-2006-4afa-9702-529fa782d63b&displaylang=en
I also installed the Software Development Kit (per their instructions):
These are the two sets that the software developer had me install.
Finally, I downloaded the .NET4 tools (based on a note in the Visual Studio readme), after things still did not work.
---------------------------------------------BEGIN MESSAGE
The script we use compiles only a fortran file, but it links to objects compiled both from Fortran and C/C++. We do need to link to C/C++ libraries in the Visual Studio distribution, as well as Intel Fortran libraries.
We call the ifortvars.bat script with the intel64 and vs2010 arguments.
Even when the Intel command prompt is launched, Mark gets the following message:
Intel Parallel Studio XE 2011 SP1
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
Intel Composer XE 2011 Update 7 (package 258)
"amd64 vcvarsall.bat"
"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\amd64\vcvars64.bat"
The specified configuration type is missing. The tools for the
configuration might not be installed.
Once that has failed, Marks PATH and LIB variables are not set up correctly.
The problem appears to be that vcvars64.bat has not been installed even though the rest of the bin/amd64 directory appears to have the right link.exe lib.exe, etc. compoents. Is this normal?
We are kind of puzzled why the Intel script compilervars_arch.bat sets TARGET_VS_ARCH=amd64 when the argument is intel64 I guess this is something specific to the installation of MS Visual Studio?
-------------------------------------------------------------------END MESSAGENote tha the following outputs were created by lines we palced in batch files for debug purposes, and are not Microsoft or Intel messages:
Or you could install the compiler that includes Visual Studio Shell and Libraries and that would probably work out-of-the-box. You don't have to use Visual Studio.
http://www.w7forums.com/vcvarsall-bat-no-64bit-support-vcvars64-bat-missing-t6606.html
thanks!
