Parameterized derived type: problem with ASSOCIATE construct.
FortranFan
module m
   implicit none
   private
   type, public :: t(n)
      private
      integer, len :: n = 1
      integer :: m_a(n)
   end type t
   public :: init
contains
   subroutine init(this)
      type(t(*)), intent(inout) :: this
      asc: associate ( a => this%m_a )
         a = 1
      end associate asc
      print *, " with associate: t%a = ", this%m_a
      return
   end subroutine init
end module m
program p
   use m, only : t, init
   type(t(n=2)) :: foo
   call init(foo)
   stop
end program p
Upon execution with either IA-32 or Intel(R) 64 compiler version:
  with associate: t%a =  0 0
Press any key to continue . . .
FortranFan
Same issue exists with a parameterized derived type with a type-bound procedure:
module m
   implicit none
   private
      private
      integer :: m_a(n)
   contains
      private
      procedure, pass(this), public :: init => init_t
   end type t
contains
   subroutine init_t(this)
      class(t(*)), intent(inout) :: this
         a = 1
      end associate asc
      return
   end subroutine init_t
end module m
program p
   use m, only : t
   type(t(n=2)) :: foo
   call foo%init()
   stop
end program p
Steven_L_Intel1
This may be one we've already seen, but I'll check it out on Monday.
andrew_4619
I must say I do not use PDTs at the moment but can see that have some useful function. I have to say FortranFan you are doing a fantastic job in giving PDTs (and other new features) in Ifort a severe beasting and perhaps in a release or two's time I might risk dipping my toes in the water when the sharks have been cleared out.  :-)
FortranFan
Thanks, I surely hope Intel doesn't mind all the posts that lead to Steve et al. having to submit tracking incidents! :-)
Re: your plan to wait until the bugs are ironed out, with PDTs yes there are a lot of issues in the current compiler version, so one has no option but to wait for a robust implementation.  But with the other features in Fortran 2003 and 2008 standards, if you do intent to use them in the near future in new code or in upgrade of your existing code, it may makes sense to start dabbling now and put together small cases that mimic your code design patterns.  I've found this firms up my understanding while also identifying any compiler issues earlier on in the code development cycle.
Now with PDTs, I do think they hold a lot of value and Intel can no sooner improve their implementation for users to start appreciating the benefits.
Steven_L_Intel1
The developers do suggest that I go on vacation more often, though this just bunches up the reports.... We do appreciate the bug reports and are interested in strengthening the PDT support as soon as we can. We have already made great strides, thanks to past reports from you and others.
Steven_L_Intel1
Issue ID is DPD200367383.
FortranFan
Thanks Steve, you deserve all the vacation you desire!  But our hope is you only "hang up your boots" after all the computing is done and the world is in nirvana!! :-))
Steven_L_Intel1
Well, this year you'll be without me for quite a bit, so get those bugs in early. (My colleagues will try to fill in...)
