29276 Discussions
Parameterized derived type: unexpected run-time error with ALLOCATABLE type with a contained type
FortranFan
I believe the following code is ok and it compiles with no errors or warnings.  But it encounters a run-time error; it appears the automatic variable in the "contained" type that depends on the length parameter is not allocated.
module m
   implicit none
   private
   type :: t(n)
      private
      integer, len :: n = 1
      integer :: m_a(n)
   end type t
   type, public :: q(l)
      private
      integer, len :: l = 1
      type(t(n=l)) :: m_t
   end type q
   public :: init_q
contains
   subroutine init_t(this)
      type(t(*)), intent(inout) :: this
      this%m_a = 1
      print *, " t%a = ", this%m_a
      return
   end subroutine init_t
   subroutine init_q(this)
      type(q(*)), intent(inout) :: this
      call init_t(this%m_t)
      return
   end subroutine init_q
end module m
program p
   use m, only : q, init_q
   type(q(l=:)), allocatable :: foo
   allocate( q(l=2) :: foo)
   call init_q(foo)
   stop
end program p
Upon execution,
forrtl: severe (157): Program Exception - access violation
Image              PC                Routine            Line        Source
p64.exe            000000013F8610F7  M_mp_INIT_T                27  m.f90
p64.exe            000000013F86125B  M_mp_INIT_Q                39  m.f90
p64.exe            000000013F861585  MAIN__                      8  p.f90
p64.exe            000000013F8F319E  Unknown               Unknown  Unknown
p64.exe            000000013F8F392C  Unknown               Unknown  Unknown
p64.exe            000000013F8F3A6E  Unknown               Unknown  Unknown
kernel32.dll       00000000772359ED  Unknown               Unknown  Unknown
ntdll.dll          000000007736BA01  Unknown               Unknown  Unknown
Press any key to continue . . .
FortranFan
To stress the point about the ALLOCATABLE attribute, the program works without it.
program p
   type(q(l=2)) :: foo
   call init_q(foo)
   stop
end program p
  t%a =  1 1
My apologies if this is a known issue; I couldn't be figure out for sure from the forum if an incident along these lines has been submitted.
FortranFan
Here's a variation of the above problem with an extended type: please note the comment on line 25.
module m
   implicit none
   private
   type :: t(n)
      private
      integer :: m_a(n)
   end type t
   type, extends(t), public :: q
      private
   end type q
   public :: init_q
contains
      this%m_a = 1    !.. this%t%m_a = 1 works.
      return
end module m
program p
   type(q(n=:)), allocatable :: foo
   allocate( q(n=2) :: foo )
   call init_q(foo)
   stop
end program p
p64.exe            000000013F5E10CD  M_mp_INIT_Q                25  m.f90
p64.exe            000000013F5E135C  MAIN__                      8  p.f90
p64.exe            000000013F66BF4E  Unknown               Unknown  Unknown
p64.exe            000000013F66C6DC  Unknown               Unknown  Unknown
p64.exe            000000013F66C81E  Unknown               Unknown  Unknown
FortranFan
Please note another variation of the extended type case in Quote #3.  With a statically declared variable, the program simply crashes without any run-time error:
program p
   use m, only : q, init_q  !.. module m as in Quote #3; q is an extended type
   type(q(n=2)) :: foo
   call init_q(foo)
   stop
end program p
FortranFan
Just trying to prevent this from falling off the radar; potentially a couple of issues with Intel Fortran compiler here.
Whoops - thanks for the reminder. Will look at this tomorrow.
Escalated as issue DPD200368557, and I included all variants. Thanks again.
FortranFan
Thanks much, Steve.
I am hoping the fixes for such issues will extend to type-bound procedures as well (you'll note the procedures in the snippets above are not type-bound).  What I have posted here are the stripped down variants where the type binding has been removed, something I was trying out to further simplify the test cases.  Since the run-time behavior appeared to be the same with or without type binding, I didn't bother submitting type-bound scenarios.  Now I can test for this when the fixed releases become available, but it will be cool if the Intel development would be so kind to look into it during their resolution phase itself!
Type-bound procedures are really a completely different thing in the compiler, not that they're without issues on their own.
But when I see a fix internally for the PDT issues, I'll try some cases with TBPs and see if I can break them.
