29280 Discussions
Passing Argumets from C to Fortran ( urgent..!!)
rampy
Hi I have a pass arguments between Fortran and C . I am able to pass
arguments and characters from Fortran to C . But passing the arguments
after manipulating it in C , I am not able to pass it back to Fortran.
Here is my code
template.f90
PROGRAM PHREEQC_TEMPLATE
CHARACTER (LEN=10)::NAME1,NAME2,NAME3
REAL NO,PH,DUMMY, sum
WRITE(*,*)'Input Name1'
READ(*,*)NAME1
WRITE(*,*)'Input Name2'
READ(*,*)NAME2
WRITE(*,*)'Input Name3'
READ(*,*)NAME3
WRITE(*,*)'Input pH value'
READ(*,*)PH
WRITE(*,*)'Write Solution Number'
READ(*,*)NO
!DEC$ ATTRIBUTES ALIAS:"_get" :: GET
!DEC$ ATTRIBUTES ALIAS:"_conc" :: CONC
CALL GET(NAME1,NAME2,NAME3)
CALL CONC(NO,PH)
READ(*,*)DUMMY
END PROGRAM PHREEQC_TEMPLATE
C Code
#include
#include
#include
#include
void get(char fname1[],char fname2[],char fname3[])
char solution_name;
char pH;
printf("The char variables from Fortran to C is: ");
printf("%s ",fname1);
printf("%s ",fname2);
printf("%s ",fname3);
void conc(float* no, float* ph)
float num1= *no;
float num2= *ph;
float sum = 0;
sum = num1 + num2;
printf("%f ",num1);
printf("%f ",num2);
printf("%f ",sum);
I want to pass Sum back to Fortran. How can I do it. I am using Intel Fortran Compiler and Microsoft Visual Basic C
Rampy
Jugoslav_Dujic
Valued Contributor II
Erm, isn't it obvious that you can do it in the same way as you passed the inputs. Either:
float conc(...
return sum;}
or
void conc(float* no, float* ph, float* sum)
{*sum = *no + *ph}
would do.
By the way, you should (at least) char(0)-terminate the string arguments to GET. Fortran does not terminate strings with �, so you can easily get garbage appended at printf().
