29274 Discussions
Passing VBA UDT with arrays to Fortran?
jchauvin
Is it possible to pass a Microsoft Excel 2003VBA User Defined Data Type (UDT) which includes numeric arrays to Fortran with Intel Visual Fortran? I have been able to pass UDT without arrays without any problems but cannot figure out how to pass the structure defined below.
Here is the VBA UDT:
Public Type DataRecord3D
nrows As Long
nr_s As Long
nx1 As Long
x1() As DoubleRedim as 1D array
x1_sOrder As Long
nx2() As Long Redim as 1D array
min_nx2 As Long
max_nx2 As Long
x2() As DoubleRedim as 2D array
x2_sOrder As Long
nx3() As LongRedim as 2D array
min_nx3 As Long
max_nx3 As Long
x3() As Double Redim as 3D array
x3_sOrder As Long
ny As Long
y() As Double Redim as 4D array
isAllSquare As Boolean
isC1C2Square As Boolean
isC2C3Square As Boolean
End Type
I'd guess that the arrays are represented as SAFEARRAY descriptors. You can use the SAFEARRAY routines in module IFCOM to decode them.
