Passing a string to Fortran
Bradley_P_1
I've had quite a lot of luck interoperating between Fortran and C# using Robert Giesecke​'s "Unmanaged Exports" library.  However, one of the things I haven't been able to achieve yet is sending a string from C# to Fortran.  The worst of it is that I get no indication of what's wrong.  My Fortran application just crashes.  From all the research I've done, it would seem to me the following should work:
C# "sender"
[StructLayout(LayoutKind.Sequential, CharSet = CharSet.Ansi)]
public struct MyStruct
    [MarshalAs(UnmanagedType.LPStr, SizeConst = 200)]
    public string Title;
    public int SourceNode;
    public int EndNode;
Fortran "receiver"
type, bind(c) :: MyFirstStruct
    character(200, kind=C_CHAR) :: Title
    integer :: SourceNode
    integer :: EndNode
end type
When I run this I get the following:
forrtl: severe (172): Program Exception - exception code = 0x4352 (17234)
Any help or ideas would be much appreciated!
Brad.
P.S.  I can include the entire source for both sides, if it helps - just let me know.
GVautier
New Contributor III
Hello
I agree about the fact that if it works from C to C# it will works from Fortran
I think you should go back to basis.
First, replace your function with a subroutine because Fortran creates a shadow argument for function returning structures a strings.
subroutine GetStruct(struct) bind(C, name="GetStruct")
	import MyFortranStruct
	type(MyFortranStruct) :: struct
!DEC$ ATTRIBUTES REFERENCE :: struct
end subroutine
and on C# side the equivalent of :
void GetStruct(MyFortranStruct *result)
   string="This is the title, padded to 200 characters just to make sure 345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890";
   strncpy(&(result->Title),string,min(len(string),200));
   result->SourceNode = 123;
   result->EndNode = 321;
   return;
2nd, on both sides (before the call to GetStruct in Fortran and in GetStruct function in C#), print the size and address of the structure and addresses of all members. They must match.
3nd, find a way in C# function GetStruct to fill an array of chars (because that's what is a Fortran string)
Bradley_P_1
Bradley P. wrote:
It is worth noting that, since the structure is created (i.e. allocated) in C#, this will likely be a memory leak.
I believe I fixed this quickly and easily by changing my C# code to the following:
        public static void GetStruct(out MyStruct myStruct)
            myStruct.SourceNode = 123;
            myStruct.Title = "This is Title #1".PadRight(200).ToCharArray();
            myStruct.EndNode = 321;
No changes were necessary on the Fortran side.
Brad.
Anthony_Richards
Bradley,
Many thanks for persevering on this and for producing a working solution. I think that the full C# + Fortran solution would make a very useful mixed-language sample to be bundled with the Intel compiler.
No doubt someone will soon want a solution that permits arrays of such structures to be accessed in a similar way!
Bradley_P_1
Anthony Richards wrote:
Bradley,
Thanks!  The solution still isn't quite as complete as I'd like, but for now it's doing the job.
Brad.
SR-9779
Bradley P. wrote:
Bradley,
Brad.
It works - Thank you. And, I have created the lib for C# dll through the steps mentioned here - https://adrianhenke.wordpress.com/2008/12/05/create-lib-file-from-dll/
What could I be missing here?
