Passing array of derived type to C
David_T_5
I have a Fortran derived type with dynamically allocated memory.
TYPE :: A
REAL, DIMENSION(:), POINTER :: array_of_reals
END TYPE A
To pass this derived type to C, I have a C struct
struct A_struct {
double* array_of_reals
When I pass the Fortran type to C, I convert the Fortran pointer to C pointer using
C_LOC(array_of_reals)
This works fine.
Now, if I have an array of TYPE A,
TYPE A_Array
TYPE(A), DIMENSION(:), ALLOCATABLE :: array_of_A
END TYPE A_Array
I cannot simply pass C_LOC(array_of_A) to C because the memory pointer allocated in each element of array_of_A is not compatible with C.  Is this correct?  If so, how can I pass an array of derived type that contain dynamically allocated memory?
It seems I need to pass an array of C pointers
TYPE(C_PTR), DIMENSION(:), ALLOCATABLE :: array_of_A
but this won't work because I cannot use dynamic arrays with BIND(C).
You can't use a derived type that contains a POINTER or ALLOCATABLE. You CAN use an allocatable or pointer deferred-shape array as a dummy argument in the 2016 version, but Fortran will pass it as a "C descriptor" (a feature from Fortran 2015) and the C code will need to include ISO_Fortran_binding.h and use the declarations in it to access the descriptor.
You can have a derived type with a C_PTR component and pass that to C.
FortranFan
@David,
See this thread:
https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/593294
If, by any size, the memory allocation and deallocation of pointer components in the struct is handled on the C side (for example, this may be a natural occurrence when the executive is on the C side and the Fortran code is more like library invocations and say the problem (array) size(s) is sent back to C from a separate Fortran call or from user input), then look at messages #11 and #12 in the above thread which describe how such C structs can interoperate with Fortran.
