Hi
Actually, this is the first time for me to try to pass arrays from VB.net to Dll created by FORTRAN, but I had too much difficulty to do that. Usually I'm having this error “An attempt was made to load a program with an incorrect format. (Exception from HRESULT: 0x8007000B)”, and I don't know why and what does it mean? .following is a very simple example I'm trying to do using VB.net:
Imports System.Runtime.InteropServices
Module Module1
Declare Sub FortranDLL Lib "C:\Users\Shabana\Desktop\DLL Project\Dll2\VBPROG\Dll2.dll" Alias "FORTRANDLL" (<[In](), Out()> ByVal Array1() As Int32, ByRef Foo As Int32)
End Module
Public Class Form1 Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim I As Int32
Dim Test As Int32() = {1, 2, 3, 4, 5, 6}
FortranDLL(Test, Test.Length)
For I = 0 To 5
TextBox1.Text = Str$(Test(I))
Next I
End Sub
End Class
Also this is the Fortran code to create the Dll file
Subroutine FortranDLL( Array1, upbound )
!DEC$ ATTRIBUTES DLLEXPORT, ALIAS: 'FORTRANDLL' :: FortranDLL
!DEC$ ATTRIBUTES REFERENCE :: Array1
!DEC$ ATTRIBUTES REFERENCE :: upbound
Implicit None
! ...argument declarations
Integer(4) :: upbound
Integer(4) :: Array1(1:upbound)
Array1 = Array1 + 10
End Subroutine FortranDLL
I hope that I could able to make it clear , and I will be do appreciated if you could help me solving this problem.
Try setting the Visual Basic project configuration to x86 if you are calling a 32-bit Fortran dll.
I notice that you declare the array to be passed by reference at Fortran side, while byval at the VB.Net side. This might be the cause of the error.
Dirk
I suggest that you study the "VB-Calls-Fortran" sample we provide. Curtis has the answer to the error message - if you leave the VB platform default as "Any CPU", it will fail to load a native DLL on an x64 system. You must explicitly select x86 or x64 depending on the architecture of your DLL.
Thank you so much Stev and Curtis
It is working now, but , I could able to pass integers only from vb.net to the dll file , but I can not pass arrays , could you please provide me some thing to help me in that
I do appreciate your help
Ahmed
Accually I could not able to reach it, could you provid me a link to it
Many thanks
![](/skins/images/DF2E495CEC88D713A66401CF495CD875/responsive_peak/images/icon_anonymous_message.png)
