Passing arrays in subroutines
Averkov__Igor
Hello!
I am interesting, in wich cases the compiler will force to allocate any of used array from the memory
Case 1:
subroutine VolFracToMassFrac(VolFrac, MassFrac)
  real, intent(in) :: VolFrac(:)
  real, intent(in) :: MassFrac(:)
end function
Case 2:
function VolFracToMassFrac(VolFrac, SubstCodes) result(Res)
  real    , intent(in) :: VolFrac(:)
  real Res (SIZE(VolFrac))
end function
Case 3:
      real Temp(SIZE(VolFrac))
end function
I am using Compaq Visual Fortran, but I am also intresting how it will be in the Intel Compiler.
Thank you
Averkov__Igor
In case 2 it would be written:
Case 2:
function VolFracToMassFrac(VolFrac) result(Res)
end function
