29285 Discussions
Passing assumed shape to Fortran from JAVA JNA
Chaitra_R_
My Fortran program contains the following:
REAL(KIND = R8), DIMENSION(:), ALLOCATABLE :: L, U
INTEGER :: N
N = 2
L(1:N) = (/0.0, 0.0/)
I modified the program and it looks like this now
INTERFACE
   SUBROUTINE inputs(L_array, arr_shape) BIND(C,name='inputs')
     IMPORT c_double,c_int,c_ptr
     type(c_ptr),value :: L_array
     integer(c_int), intent(in), dimension(2) :: arr_shape
   END SUBROUTINE inputs
END INTERFACE
SUBROUTINE inputs(L_array, arr_shape) BIND(C)
     USE ISO_C_BINDING
     USE VTdirect_MOD
     IMPLICIT NONE
       integer, intent(in), dimension(1) :: arr_shape_L
       real, dimension(:), pointer :: L
       integer :: n
       call c_f_pointer(L_array, L, arr_shape_L)
       print *, "L in fortran:", L
       do j = 1, n
            print *,L(j)
       end do
END SUBROUTINE
My JAVA program contains the following lines
double[] l = new double[]{0.0,0.0};
    int[] y = new int[]{2};
lib.inputs(l,x);
But, when I run this program,
I get the following output
L in fortran:   0.0000000000000000        0.0000000000000000
6.9518704107813286E-310
   1.3339772437713657E-322
What am I doing wrong?
Since you declared the array "double" in Java, you should use real(C_DOUBLE) in the Fortran declaration of L.
mecej4
You posted code fragments that the compiler rejects, because there are a number of syntax errors. Obviously, the code that you posted is not the code that you ran. I cannot make sense of your claim that you modified a program such that it became a much bigger subroutine.
The interface block is of little use -- it is meant for use by callers of the subprogram concerned. Therefore, in Subroutine Inputs()  there are variables of undeclared type.
Please post the actual code.
FortranFan
mecej4 wrote:
... I cannot make sense of your claim that you modified a program such that it became a much bigger subroutine.
Where is this claim?
It's in the original post. Basically, a small Fortran program was turned into a Java program that called Fortran code. The Fortran code is larger than it needs to be.
Chaitra_R_
I looked into this post here - https://software.intel.com/en-us/forums/topic/282360 and I changed my SUBROUTINE inputs to look like this:
SUBROUTINE inputs(array_ptr, array_size) bind(c)
USE ISO_C_BINDING
IMPLICIT NONE
TYPE(C_PTR), VALUE :: array_ptr
INTEGER(C_INT), INTENT(IN), VALUE :: array_size
INTEGER(C_INT) :: i
REAL(C_DOUBLE), DIMENSION(:), POINTER :: array
call c_f_pointer(array_ptr, array, [array_size])
DO i =1, SIZE(array)
PRINT *, array(i)
END DO
My Java program now contains the following lines of code:
double[] arr = new double[]{0.0,0.0};
int n = 2;
lib.inputs(arr,n);
The output is given below and as expected.
   0.0000000000000000
   0.0000000000000000
Thank you so much for all your help. Next time, I'll make it a point to include the full code and format my code properly.
