29652 Discussions
Passing character array to a subroutine using a pointer
men8th
I need to pass a character array to a subroutine using a pointer. If I pass a character variable (i.e. not an array) as below then everything works OK:
Code:
 program Test_Project
   character(10), target :: strings
   character(10), pointer :: pstrings
   strings = 'string 1'
   pstrings => strings
   call test_sub(pstrings)
 end program Test_Project
 subroutine test_sub(str_in)
   character(len=*), intent(in) :: str_in
   print*, str_in
 end subroutine test_sub
However, if I attempt to pass a character array as follows then I get warning messages from the compiler about passing a character value toa non-character dummy argument and the code crashes when run.
Code:
   character(10), dimension(10), target :: strings
   character(10), dimension(:), pointer :: pstrings
   pstrings => strings
   character(len=*), intent(in), dimension(:) :: str_in
   print*, str_in
What's going on? Any help or solutions would be most greatfully recieved. Cheers, Tim
men8th
Steve, thanks very much for the help. Looks like you've grown pretty tired of answering that question as you've gone to the trouble of putting the answer on a web-page!
Cheers, Tim
It's actually an article I wrote several years ago, but this question does come up a lot!
