Problem with required data type
h-faber
I am going slightly mad trying to fix the following error message:
"A CHARACTER data type is required in this context"
The code I got looks like
CHARACTER*(*) VAR1
VAR1 = SCHAUM()
CHARACTER*(*) FUNCTION SCHAUM ()
SCHAUM = 'SCHAUMSCHLAEGER'
RETURN
END FUNCTION SCHAUM
It does not help if I replace the *(*) figures by (len=80) or so. Besides I have no idea about the meaning of CHARACTER*(*) VAR1, haven't found any documentation about it.
Anyone here knowing more about this issue?
TIA
H.
wkramer
You probably need an explicit interface to function SCHAUM(), so the compiler knows that SCHAUM returns with a character variable.
Add something like:
Interface
RETURN
END FUNCTION SCHAUM
End interface
to your declarations.
Walter
h-faber
Hello Walter,
adding your two interface lines unfortunately does not change a thing, still the same error message. What might be of interest is that this code is contained in a file which begins with
SUBROUTINE MyFunc(Var1, Var2, Var3)
Maybe this plays a role in this issue?
wkramer
Sorry, I have been a bit messy in my reply.
The following code for a complete program shows what I mean.
A charcacter*(*) function return value is not accepted in an interface block, so I changed it into character(len=15).
Walter
Code:
    program CharString
      implicit none
    ! Variables
      CHARACTER(len=80) VAR1
    ! Body of CharString
      CALL MyFunc(Var1)
    end program CharString
    SUBROUTINE MyFunc(Var1)
      implicit none
      CHARACTER*(*) VAR1
      Interface
        CHARACTER(len=15) FUNCTION SCHAUM ()
        END FUNCTION SCHAUM
      End interface
      VAR1 = SCHAUM()
    END SUBROUTINE
      implicit none
      RETURN
    END FUNCTION SCHAUM
Message Edited by wkramer on 03-18-2005 04:57 AM
h-faber
Hello Walter,
thx a bunch, I got it working now. :)
