29375 Discussions
Passing negative indexed arrays to a subroutine
Navdeep_Rana
Say I define and allocate array
integer, parameter :: n = 128
real,dimension(:) :: u
allocate(u(-1:n+2))
Now I would I like to pass it to a subroutine,
subroutine do_something(u)
real,dimension(:),intent(inout) :: u
u(-1) = 0
end subroutine do_something
This ends up with a warning. How do I let the subroutine know that the array has negative indices?
jimdempseyatthecove
Look at Assumed-Shape Specifications in the documentation.
If your array size is unknown, but the array base index is always -1, then
  real,dimension(-1:),intent(inout) :: u
  u(-1) = 0
** keep in mind the note in the documentation that assumed shape array passing requires an interface for the subroutine/function (if not within a module).
Jim Dempsey
jimdempseyatthecove
Or Assumed-Rank specification:
  real,dimension(..),intent(inout) :: u
  if(RANK(u) .ne.1) Stop ! 1D array only
  print *,lbound(u)
  u(-1) = 0
Jim Dempsey
