29653 Discussions
Passing non-consecutive array indicies
gtopo30
I am working on porting code I didn't write from pgf90 to ifort and I have run into a difference between the two compilers I don't know how to fix.
Here is an example. I have a matrix A which is 5 by 7 elements. Based on tests elsewhere in the code, I construct a vector of "good" rows. So I have good_rows who's values are {1,2,4,5}.
Now, with pgf90 I can pass just the good elements via something like this
call workfn(A(good_rows,:),...)
However, when I compile with ifort (v9 build 20051201) I do not get an error but I will get a segmentation fault at run time.
I hope this is enough info. Any thoughts?
Case
It's not enough info, because we would also need to see:
1. Any explicit interface for workfn visible to the caller
2. The subroutine statement and declaration section from routine workfn
Let me suggest, though, that you may be encountering a bug which was fixed a few months ago. The compiler you are using is six months old. Please download and install 9.1.032 from Intel Premier Support File Downloads and see if that helps. After installing, be sure to invoke the proper ifortvars.sh so that you get the newer compiler.
gtopo30
Thanks Steve,
I upgraded to 9.1.032 and that didn't change the behavior.
A is declared as a double precision, allocatable, pointer.
good_index is declared as integer, allocatable, pointer.
The subroutine workfn is pretty simple:
subroutine workfn(mat, sum)
implicit none
double precision, dimension(0:,0:), intent(in) :: mat
double precision, dimension(0:), intent(out) :: sum
The routine runs through a series of mostly simple math to fill out the vector 'sum' based on the "good indicies" of 'mat'.
I hope this helps.
Case
Is an explicit interface for workfn visible to the caller? It needs to be as the routine has assumed-shape array arguments.
If that's not the problem, then please submit an example to Intel Premier Support and we'll be glad to look into it.
gtopo30
Unfortunately, when I try to log in to "Premier Support", all I get is this page:
https://premier.intel.com/scripts-util/quaderror.htm
However, I was able to duplicate the problem in the following manner:
Main Program :
program main
use hmatrix_mod
implicit none
type (HMatrix) :: This
double precision :: ds
integer, allocatable, dimension(:) :: mIndex
integer :: i, j, k, good_ind
good_ind = 1400
allocate(mIndex(0:good_ind-2))
do i=0,49
mIndex(i) = i
end do
do i=51,good_ind-2
mIndex(i-1) = i
end do
call init_hmatrix(This,good_ind)
call workfn(This%HMatrixValues, ds)
print*,'Passing all, ds = ',ds
call workfn(This%HMatrixValues(mIndex,:),ds)
print*,'Passing some, ds = ',ds
nullify(This%HMatrixValues)
deallocate(mIndex)
end
With one subroutine:
module hmatrix_mod
implicit none
type HMatrix
double precision :: HMatrixMinValue
double precision :: HMatrixResolution
integer :: HMatrixNumColumns
integer :: HMatrixNumRows
double precision, dimension(:,:), pointer :: HMatrixValues
integer, dimension(:,:), pointer :: HMatrixValueRowIndex
integer, dimension(:), pointer :: HMatrixNum
end type HMatrix
double precision, allocatable, target, save :: HMatrixValues_mat(:,:)
integer, allocatable, target, save :: HMatrixValuesRowIndex_mat(:,:)
integer, allocatable, target, save :: HMatrixNum_mat(:)
contains
subroutine workfn(matVal, sum)
implicit none
double precision, dimension (0:,0:), intent(in) :: matVal
double precision :: sum
integer :: i, j, k
sum = 0.d0
do i=0,size(matVal,1)-1
do j=0,size(matVal,2)-1
sum = sum + matVal(i,j)
end do
end do
return
end subroutine workfn
subroutine init_hmatrix(HM, indx)
implicit none
type(HMatrix), intent(out) :: HM
integer :: indx, i, j, k
&nbs p; if(allocated(HMatrixValues_mat)) then
deallocate(HMatrixValues_mat)
endif
if(allocated(HMatrixValuesRowIndex_mat)) then
deallocate(HMatrixValuesRowIndex_mat)
endif
if(allocated(HMatrixNum_mat)) then
deallocate(HMatrixNum_mat)
endif
allocate(HMatrixNum_mat(0:indx-1))
allocate(HMatrixValuesRowIndex_mat(0:indx-1,0:indx-1))
allocate(HMatrixValues_mat(0:indx-1,0:indx-1))
HMatrixNum_mat = 0
HMatrixValuesRowIndex_mat = -1
HMatrixValues_mat = 1.d0
HM%HMatrixValues => HMatrixValues_mat
HM%HMatrixValueRowIndex => HMatrixValuesRowIndex_mat
HM%HMatrixNum => HMatrixNum_mat
end subroutine init_hmatrix
end module hmatrix_mod
Everything was compiled with
ifort -mcmodel=medium -g -CB -i-dynamic -fpic main.f90 hmatrix_mod.f90 -o Main
This causes the same behavior (segmentation fault) as the program earlier.
Case
jimdempseyatthecove
Case,
You have a programming error:
do i=0,49
mIndex(i) = i
end do
do i=51,good_ind-2
mIndex(i-1) = i
end do
Allocates from mIndex(0) thru mIndex(good_ind-2)
The second do loop finishes up at
mIndex(good_ind-2-1)
where the array mIndex ends at good_ind-2. This results in mIndex(good_ind-2) being undefined.
Don't know if this is causes the error message you are seeing. But using an initialized index is not good.
Jim Dempsey
jimdempseyatthecove
One more thing.
The way you havethe calls to workfn coded will result in a temporary array being created. It may be more efficient to pass in the entire array plus an integer array of the selected rows (using -1 to indicate end of list or row not selected). In this manner a temporary array is not created. This results in faster runtimes as well as reducing stack requirements for temporary arrays.
Jim Dempsey
gtopo30
Jim,
Thanks for catching that error.
It appears the error is due to the temp array and the stack size (ulimit -s unlimited fixes the problem).
Unfortunately, I inherited this project and its going to be a mess to fix it.
Thanks again for all the help!!
Case
Ron_Green
Case,
You might try options -O0 -g -traceback -check bounds
this will help catch other array bounds issues that might be hiding in the code.
jimdempseyatthecove
Case,
The stack size issue is a build and run environment issue and other than for performance and memory capacity requirement is not a fundimental problem with the old code you inherited.
Invalid subscripting though is a fundimental problem with the old code you inherited. As suggested in another reply, it would be well worth your time to make a few runs with the array subscript checks as well as the uninitialized variable checkoptions enabled. "A stitch in time saves nine."
Jim Dempsey
